Results 1 to 8 of 8
Thread: E38 scaning with scan tool
    Oct 2006
    Default E38 scaning with scan tool
    guys sorry not on here much with work and a mod. on pt.net just dont browse alot.I am trying to find out why my scan tool is not working the dash pops up and i can get it to connect but when i go to record it blinks and shows nothing gauges don't do nothing.i have it set on E38 ecm Imperial.pid's.
    can anyone please tell me what i am doing wrong just for a little more info i am tunning an 2001 truck,2005 tahoe,2007 vortex max,2009 4x4 6.2 i am haveing the problems with the 2 newer trucks
    thanks for any and all help.
    Hi LD,
    Can you post some screenshots...?
    [go CTRL-PrtScrn and paste/save into Paint or IrfanView, then when replying click Go Advanced and Manage Attachments. ]
    Did you press the connect button to connect to vehicle...?
    Did you select pids...?
    Oct 2006
    i have selected E38 ecm Imperial.pid's.
    i press the gren botton on top left corner then the red botton for recorder when i hit the red botton it does nothing.i was in the pass able to log and everything wrok good when i started to tune on my 01 from then on it has not worked.
    Oct 2004
    The E38 PIDs will likely not be supported on your 2001 vehicle and may simply be the problem. Perhaps try selecting Default Imperial PID list and try that as a comparison.
    Andrew
    EFILive Crew
    Can you post some screenshots of the the Data tab.
    Oct 2006
    i'll try
    Quote Originally Posted by litreddevil View Post
    i'll try
    See here for instructions: showthread.php?t=3064
  1. Tuning tool not following scan tool (VE table)
    By dvx in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2008, 09:43 AM
  2. Scan tool match tune tool?
    By zapp168 in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 05:27 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Fit to Scan Tool/Tune Tool
    By limited cv8r in forum General
    Last Post: March 3rd, 2007, 06:10 AM
