Will increasing Min throttle position {B0806} to 200% stop it from going into COT? I had at 200% but would go into what I thought was COT, after first lap and numbers spot on it would go fat about BEN .94 after hard front straight pull. At first I didn't think it was COT because I thought it was off because I previously had set min throttle at 200%. I kept raising the WOT temps by 20% but without max temps indicating above 1065*C I was beginning to think it would be crazy hot.
Also I'm pretty sure it's going over 1065*C but that's all it will register in CATTEMP {GM.CATTEMP}
Any way to know what the fuel adder and timer is or turn it off? Seems it's about 1.06 and until you turn the car off or get off track.
Track only car with no cat.
