Results 1 to 7 of 7
Thread: allison dvt
    Nov 2008
    Default allison dvt
    I had my 02 duramax on the dyno the other day and even with the dvt locked in fourth it would still upshift into 5th. It would prevent downshifts but not upshifts. Is there a way to prevent this or do I just reflash the tcm with a higher 4th-5th wot upshift before I put it on the dyno? It was still climbing at 3250 when it was shifting.
    Jan 2008
    just lockout 5th gear with your gear selector. (hold the T/H button)
    May 2006
    Quote Originally Posted by bballer182 View Post
    02's do not have a 5th gear lockout unless you add it by running an extra wire to the TCM and install the updated GM cal/os.
    2001 K2500HD Duramax/Allison
    Jan 2008
    Quote Originally Posted by jimter View Post
    I know what id be doing...
    Nov 2008
    anybody have a writeup on this or know where to find one? And where do I find an updated gm cal/os
    May 2006
    Try This
    http://www.kennedydiesel.com/docs/Al...ut%20final.htm
    Also Go to and enter your VIN to find the latest Cal
    http://tis2web.service.gm.com/tis2web
    Nov 2008
    thanks I'll take a look at that
  1. Allison DVT's
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: October 17th, 2009, 02:36 PM
