Well, Joecar you finally 'broke' my car....just kidding.
For now, I will just post the tune & Log. Joecar had me do an interesting test. I put Table B3618 to the same value as B3601 (stoich). For B3616, Normal PE Mode Enable all TPS values were put to 10%.
Table B3605 was purposely changed to a richer value of 13.0 AFR at normal engine operating temperature.
Results:
1. Car started normally using the Table B3605.
2. Car went into Closed-Loop at 34C (normal).
3. When PE mode was hit, car went into OL-Drive..commanding 14.629 AFR. At 10% TPS it stayed continuously in OL-Drive.
4. 5-10 minutes later it attempted to do its EVAP Purge (FTC cell 22). It was unable to do its EVAP purge (cell 22 is also WOT). Car immediately threw a DTC Code P0131 and P0137..and defaulted into the Table B3605.
Pulled car over, cleared codes..reloaded 'normal' tune. Everything worked out.
Joe, or anybody else who might be interested. PE Mode (in my OS) seems to always initiate OL-Drive. When in OL-Drive, the EVAP Purge is not active. Believe me it was not long before I smelled gas fumes and I went rich. No Trim, no EVAP..it did not like that 10% TPS enabler. To minimize pids, I did not log IPW or H02S11..but my O2 sensors pulled a DTC and I found an unique way to use the OLFA Table..
Joecar interesting experiment, but the U.S. EPA may have done something tricky with FTC cell 22 and EVAP. Thats my theory. Any thoughts?
