Results 1 to 10 of 15
Thread: DSP5 Installation help...
    Junior Member duramax07tmd's Avatar
    Feb 2010
    Default DSP5 Installation help...
    I just recently purchased the V2 and a DSP5 for my 07 LBZ. I did a search and could not find anything on how to install the DSP5 switch. Is there a thread with a HELP for installing the DSP5 switch? Or does anyone have any pictures on where to hook up the wires?
    Im still new to the EFI world and i am still learning day by day. Any help would be greatly appreciated!
    Thanks in advance!
    07 Chevrolet LBZ
    CCSB 4x4
    EFI Live DSP5 Duramaxtuner.com
    PPE & Aeroforce Gauges
    5" MBRP & DE Direct Pipe
    EGR Blocked & PCV Reroute
    PPE Ported Fuel Fittings
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Apr 2007
    Here is the tutorial from the EFILive website:
    http://download.efilive.com/Tutorial...%20LBZ-LMM.pdf
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Sep 2007
    The tutorial is pretty nice, the install isn't bad, one thing is to make sure you are looking at the plug the correct way. I was backwards my first attempt
    Feb 2010
    Ok thanks guys i appreciate it!
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Feb 2010
    how long would you say it takes to install the switch? Wires, switch mount etc... Just roughly?
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Apr 2007
    1 hour or 2?
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Junior Member johnasara's Avatar
    Nov 2009
    The actual install takes longer than hooking it up. I taped the two pins together to pull it thru the firewall. That way I did not knock one off. I have heard of alot of people knocking one off trying to get it thru the fire wall. The rest is pretty easy as well just finding where to mount the switch was the hardest part for me. Your truck is still old enough your interior panels just pop on.
    06 CCLB LBZ
    Diamond Eye Exhaust, EFI BY MMLMM, S&B intake, Transgo JR, EGR Blocked,
    04.5 LLY
    5" Diamond Eye exhaust, EFI BY KORY,LBZ PIE HOLE- Cause LLY cant breathe
    Feb 2010
    k thanks Johnasara
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Feb 2010
    Alright, i received my V2 and DSP5 today. Im gonna install everything tomorrow. My switch seems loose, like it turns all the way around and takes a long time to "click" How do i tighten up my dsp5 switch so it clicks and changes tunes right?
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Mar 2007
    There is a set screw with a small allen head that needs to be tightened in the knob.
    2007.5 RCLB 4x4 WT LMM 8594OS
  1. Guts Kit installation
    By SS2win in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 6th, 2015, 01:41 AM
  2. User installation
    By BackinBlack02SS in forum FlashScan V2
    Last Post: November 26th, 2008, 10:41 AM
  3. LC1 hook-up/installation
    By SPRAYED07 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 8th, 2007, 07:36 AM
  4. Software Installation
    By GHamm in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 19th, 2007, 08:29 AM
  5. PLX M-250 Installation
    By Patches in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2005, 07:43 AM
