Results 1 to 5 of 5
Thread: What a/f to start tuning my dry shot?
    Aug 2007
    Default What a/f to start tuning my dry shot?
    Installing a dry shot this weekend on my Z. Looking for input on what my a/f ratio should be before I hit the button on the 100 shot. No maf, just tuning with serial lm1.
    THANKS...
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
    Apr 2008
    I guess the shot is small;
    To be in the safe side with the shot, AFR shall be 11.7 ....... and take 2 deg every 50 hp
    Before the shot the AFR can be whatever u like between 12.5 to 12.8
    For your setup (dry), it would be better if you use COS. COS will have your car at optimum condition with and without NOS.
    Or tune it for the two conditions, and swap between them as required.
    Good luck...OB
    Regards,
    Odd Boy
    Aug 2007
    Yeah, I was looking for what to tune the A/F to prior to the shot before hitting the button. IE : i tune mine to 10.5 and hit the button and a 100 shot takes it to 11.7. I'll lower the timing and get logged and try some stuff. I was looking for an idea to start with though...
    Thanks for replying
    Apr 2008
    So do u got the idea through what I said...
    Regards,
    Odd Boy
    Aug 2007
    http://www.ls1tech.com/forums/nitrou...-dry-shot.html
    Link to the story of how it turned out...
  1. About to start tuning, need some help
    By hyper24 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 16th, 2009, 08:58 AM
  2. just got EFI live where to start tuning
    By SimpleManLance in forum Gen III V8 Specific
    Last Post: December 7th, 2007, 07:06 AM
  3. WTB: New to tuning and don't know were to start
    By ThunderV in forum General (Diesel)
    Last Post: October 16th, 2007, 07:19 PM
  4. Tuning a 400 shot on a 408
    By minytrker in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 28th, 2006, 03:21 PM
  5. Things you need to start tuning
    By bobo in forum General (Diesel)
    Last Post: March 8th, 2006, 09:17 AM
