trying to download updates, when i click on link it says website not found! Does anyone know if the server is down?
What is the link you are using?
Brian
2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
it wont let me paste the link here, but this is what i'm trying to get! i've tried the link from several places. (V7.5.6.100 87Mb).
I suggest this link here for the latest.
http://forum.efilive.com/showthread....ewpost&t=13140
Brian
A long time ago now we changed the installer behind the EFILive software, which includes a different update component. The installer we used prior to this did deliver on the promise of auto updating so we had to change to another product.
We recommend people install (at the time of this post) the latest RC from here: http://forum.efilive.com/showthread.php?t=13140
If you are running an older version you will need to uninstall the EFILive software (we recommend backing up the 'C:\Program Files\EFILive' and 'Documents\EFILive' folders prior to this) and then installing the new base.
Andrew
EFILive Crew
thanks for the replies, those links worked however after downloading the updates i still get the message pcm unrecognisable!
Ok. So what sort of Duramax is your vehicle (LB7, LLY, LBZ or LMM)? In the calibration you have what is the OS # shown as?
If you are trying to read the ECM make sure you select the correct controller type.
Andrew
EFILive Crew
its lmm, im trying to load tunefile from email, but it keeps saying pcm unrecognisable!
Even though it says it is not supported or unknown it will generally still show the OS#?
Andrew
EFILive Crew
52628594
