injector or coil data does not change on scan tool while cranking.
I preformed a "full" reflash with vats off and still no start.
just reviewing my tune file and noticed the it was a type 2 vats patch. Should I try to reflash it as a type 3..
Trevor
2 or 3 should work, either one sends the ECM down the right path.
I thought even with the VATS still active, the engine will fire briefly, like 1/4 of a second just to let you know, yes everything is ok but I am not going to allow this engine to keep running.
I also thought the request to crank was a discrete input not a GMLAN message (I think the discrete input is J1-52, but I don't know that is 100% correct). I confess, that is beyond where I normally deal with so I am not sure. The ECM does seem to get grumpy when the starter relay output is left open circuit (J1-67).
Maybe post up your file too.
there is got to be a way to tell the pcm to start other then the GM LAN message from the bcm...... Is this PCM in an older vehicle that may not need a GM LAN message and has like a 12 volt input to the pcm to start...
Trevor
Just for fun some OS's use J1-67, others J1-52. Seems J1-67 is earlier, J1-52 later. Vegasrobbi has had success with a resistor in circuit so it looks like it expects to see some idle current to ground.
And to make it just a little more perplexing even some OS's that use this J1-52 crank relay control will start on the second crank and some wont.
Will give it a shot this morning and report back.
Unfortunately the request to crank is generated via the BCM which the ign switch connects to. There are no wired inputs in relation to this so can only assume it is one of those functions like cruise control that has disappeared into the mysteries of the GMLAN.
what do you mean by J1-52..... connector 1 terminal 52..
What about the GMPP standalone E38/E67, what do they use for crank request?
