Results 1 to 5 of 5
Thread: one or more invalid checksum segments
    Member SGFastMax's Avatar
    Apr 2009
    Default one or more invalid checksum segments
    i have a DSP5 tune on my 06 LLY and when i read the calibration data from the ecm at the end a message comes up that says "this calibration containes one or more invalid checksums and is unsafe" ect... by looking at the calibration deffinition file number it goes on to the pcm as a DSP5 tune but comes off with the stock .calz number and there is no custom os there. i tried doing a full reflash and nothing changed. the truck still runs the way it should and all the configured DSP tunes are there. i just cant read off the pcm. anyone know whats going on?
    Apr 2007
    You cannot read a DSP5 tune. Flashing only, that's why you save the DSP5 tune is a safe location.
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Apr 2009
    i read a DSP5 tune from an LB7 before and never had this problem. but i do remember reading about this when i first ran the DSP tune.
    On the 06 LLY you can't read back the tune, this is a limitation of the Bosch ECM. Was never an issue with the LB7 or early (non Bosch ECM) LLY.
    With the invalid checksums, some hand held tuners will cause this error, so if it still has that tune in then that is your problem.
    Apr 2009
    ok then there is no problem, thanks for your help.
  1. E38 w/ No transmission Segments
    By Shupe in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 14th, 2008, 01:32 AM
  2. Bad Checksum?
    By 8100 Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 2nd, 2008, 11:18 PM
  3. Fuel Segments for 1998 T/A
    By KAZ MotorSports in forum Gen III V8 Specific
    Last Post: May 14th, 2008, 05:12 AM
  4. Checksum Fix ?
    By Ninety8C5 in forum FlashScan V2
    Last Post: May 2nd, 2008, 08:46 AM
