Yes i have plugged everything in before i opened the tune. I will go try it again just to double checked. I feel like i have done everything. I have worked on it since 8AM this morning.
07 Chevrolet LBZ
CCSB 4x4
EFI Live DSP5 Duramaxtuner.com
PPE & Aeroforce Gauges
5" MBRP & DE Direct Pipe
EGR Blocked & PCV Reroute
PPE Ported Fuel Fittings
AirDog II 165
HD Tie Rod Sleeves
S&B Intake
Just to be sure, Turn the truck to the "on" position first, plug usb in, plug the the truck, then open the software?
07 Chevrolet LBZ
CCSB 4x4
AirDog II 165
HD Tie Rod Sleeves
S&B Intake
step 1. plug V2 into the laptop via the USB cable.
2. open the tune file
3. connect the V2 (while still connected to the laptop) to the OBDII port via the supplied cable.
4. click the "full flash" button (the WIDE red button)
5. follow the instructions.
ok, now at what point do you turn the key to the ON position?
07 Chevrolet LBZ
CCSB 4x4
AirDog II 165
HD Tie Rod Sleeves
S&B Intake
in between 2 and 3. sorry
ok thank you ill try it again!
07 Chevrolet LBZ
CCSB 4x4
AirDog II 165
HD Tie Rod Sleeves
S&B Intake
I just wanted to say thank you to all that have responded to my post. I worked all day on learning this software. I just now got my DSP tune flashed into the truck. I was very frustrated this afternoon, but i feel much better now.
Again, thank you to all that helped me with my issue!
Feel free to delete this thread if needed.
Thanks.
07 Chevrolet LBZ
CCSB 4x4
AirDog II 165
HD Tie Rod Sleeves
S&B Intake
Your welcome. Was the issue having to plug the V2 in before opening the Efilive 7.5 software?
Brian
2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
Was doing a search on google and this "[deleted reference]" title came up...not too cool just lettin ya know cause obviously...it made someone really happy once they were tutored....to the poster...Welcome to the forum!
Yea, shows you the importance of words.
You get mad..take it back, but Google does not forgive!
To the OP, glad you got it worked out. Having gotten frustrated a few times in life..I try real hard now to take 24-48 hours before I post in anger.
All understandable..A good lesson for all though..
