Results 1 to 7 of 7
Thread: Hard to start when hot
    Jan 2008
    Default Hard to start when hot
    When I start the truck at operating temp it will idle at very low rpm and die. If I aplly slight throttle it will start and run fine. What should I adjust to cure this problem?
    Truck is a 97 yukon 383 with marine intake and 0411.
    Wes
    Nov 2007
    Table B4307
    Jul 2008
    Table B4307 Desired Airflow is a good place to start (as previously mentioned). Usually that means adding air. You can look at some of the Idle Tutorials on how to do that.
    Another Table that can really help is Table B4343 Startup Friction Airflow Correction (depending on your OS). You can easily add 1-2 g/s to the specific ECT you are having trouble with. That extra air decays rapidly..so you just get the additional airflow at startup.
    Hope that helps.
    Jan 2008
    I tried adjusting both of those tables with no success. Here is my tune.
    Jul 2008
    Well if you legitimately adding Airflow and that does not work..I would start thinking Base Spark in Gear. Perhaps it is too low?
    Quite frankly, Idle Tuning problems are tough to diagnose. I actually had a lot of success following the Idle Tuning Tutorial..http://forum.efilive.com/showthread.php?t=4661.
    I literally went through line by line, especially on modifying the Idle Learning Parameters. I spent about 2-3 days with my car until I got it down.
    Have you modified your B3605 Table? Is it really 14.68 AFR all the way across (stock). If it is a hot start and too lean, you can stall. I am just throwing a few things out there. Adding Airflow usually works...
    Good luck..
    Jan 2008
    Thanks weatherman! I went through that tutorial and changed a few items. It did not work at first but after a few days the truck starts without hesitation.
    Wes
    Jul 2008
    Good Job!
    Let us know how it goes. Then the next hot start-up problem someone has..you can give them some help..
  1. Hard start condition with 5.7 in 2000 S-10
    By lowriders10 in forum Vortec V6/V8 Specific
    Last Post: May 30th, 2010, 03:56 PM
  2. Wasnt sure how hard EFI was???
    By cjms in forum EFILive V4
    Last Post: December 11th, 2009, 07:59 PM
  3. what is a hard start?
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 23rd, 2007, 04:02 AM
  4. would this be hard
    By zrx1200 in forum Custom Operating Systems
    Last Post: August 7th, 2006, 08:29 AM
