Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Erratic AFR/voltage in EFILive
  1. #11
    Jun 2008
    I have reprogrammed my LM1 before the log to the LC1 specs to get a higher resolution in AFR:
    0.88333 Volts at AFR: 10.00
    4.21667 Volts at AFR: 20.00
    I recently learned that the V1 goes only to 4.8V so I chose these specs instead of the standard LM1 specs
    I changed the sae_generic file accordingly.
    Could there be anything wrong with the pid itself?
  2. #12
    Nov 2006
    Your AFR PID needs to be based off {B3601} for BEN factor to be correct.
    Check the fuel settings in the LMProgrammer software.
    When was the last time you calibrated the sensor in free air?
    LC-1 WBO2
  3. #13
    In calc_pids.txt you need to base your AFR equation on those end points (post #11)...
    i.e. you can use CALC.AFR_LM11 and CALC.BEN_LM11.
  1. Erratic AFR's at the track?
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: September 27th, 2008, 04:26 AM
  2. Changed my IFR...AFR Is erratic
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 05:19 AM
  3. LC-1 WB voltage Q?
    By 99Silver6.0 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 28th, 2006, 10:55 AM
  4. TPS voltage
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2006, 03:41 AM
  5. Erratic LTFTs after VE tune
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2006, 11:36 AM
