How do I get the scan tool to always read metric
Edit -Properties->Options->Preferred Units.
Also, on the PIDs tab, do ctrl-A to highlight all pids, then do rightclick->Metric, and close the scantool.
Thanks.
One more, in HP tuners I want to log desired idle; I can't seem to get it to jive here. It doesn't look like it's a supported parameter.
I'm also trying to find a setting that has to do with timing; going from park to drive it goes to "minimum spark advance setting" then back to "in gear" setting. still trying to find post in forum as well about it. Does this ring a bell?
wp
wp,
You mean this pid: GM.IDLEDES...?
On the pids tab, click on the column heading "Caption" to sort by that column...
then scroll down until you see IDLEDES in the Caption column... double click on the row to select the pid.
jc
Look down the [sorted] Caption column until you see pids named EST_xxxx...
EST = Electronic Spark Timing...
Are EST_IDLE_DMA and EST_BASE_DMA what you're looking for...?
On some pids you can go rightclick->More Info to get a description of what they do...
Paul is over time filling in the descriptions of the ones that don't have more info.
I went to parameters in the scanner and set it for metric. it still always opens in imperial.
