I was playing around making a cax file last night & came to a blank when it came to the table number to use.(I was on my other computer) This had me thinking about when we share .cax files & end up with similar table numbers for different parameters. So here is the list of table numbers I have used on top of the transient tables that MICK first made. I figure if we keep a registry on what table numbers we have used it will make it much easier in the future.
Can those others making .cax files add to the list?
{B0121} Dynair calculation hysteresis
{B9000} Impact factor
{B9001} Stomp make up fuel
{B9002} Impact factor modifier
{B9003} Boiling time constant
{B9004} Boiling time modifier
{B9005} Wall mass factor
{B9006} Wall wetting min rpm
{B9007} Wall wetting max tps
{B9008} DFCO stomp compensation tps min
{B9011} Prior stomp compensation reduction
{B9012} Initial stomp compensation time
{B9013} Stomp compensation delay
{B9014} Minimum stomp fuel
{B9015} steady state enable/disable threshold rpm
{B9016} steady state map
{B9017} low map delta kpa
{B9018} high map delta KPA
{B9019} Delta tps low
{B9020} Delta tps high
{B9021} Min pulsewidth in transient conditions
{B9022} A/C Default airflow drive
{B9023} A/C Default airflow P/N
{B9024} End of injection timing trim
{B9025} End of injection timing Normal
{B9100} Lean Cruise enable
