Results 1 to 9 of 9
Thread: Which side to install wideband on
    Lifetime Member Gregs's Avatar
    Sep 2008
    Default Which side to install wideband on
    well since this is my first post I guess I should say hi all!
    the other day I got a v1 and a lc-1 wideband. i'm getting ready to install it on my truck and i'm wondering if i should install it on the right or left side collector. does it matter because i think i've heard that the passenger side is the best place.
    thanks!
    Hi Gregs, welcome to the forum...
    Which truck do you have...?
    Sep 2008
    03 silverado 5.3 4wd ecsb
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Jul 2007
    Normally, the passenger side is preferred as you have a bit more room to route cables etc. It also brings the cable into the cab in a place away from the driver, keeping the driver free from clutter.
    Technically speaking, it doesn't really matter which side it's on if you are only using a single WB as the only time the the banks are considered as separate entities is for closed loop fueling. Even then, there is very very little to adjust on a "per bank basis". All other calculations for air flow, spark etc effect the entire motor and are not bank specific.
    Simon
    Oct 2006
    On the trucks Driver side is best , LS1s tend to have a lean bank , drivers side .
    Either one will work , but in the trucks drivers side is easiest for power , ground and such .
    2006 Trailblazer
    Sep 2008
    thanks for the quick reply. i've searched around but have come up dry, does anyone know of any good how-to articles out on the web anywhere?
    Stock for now
    Jan 2007
    Yep...drivers side. Apparently the number 7 cylinder has a tendency to lean out.
    Hmmm...assuming you're in the US (LHD).
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    is there any significant reason that a single cylinder would lean out? as you put hquick #7. i have mine installed into the pass. bank but would concidering switching when i redo my exhaust
    Jan 2007
    I've read it in alot of other forums...no idea why though.
    Howard
    DUCT TAPE.
  1. FJO wideband install
    By sinr98 in forum Gen III V8 Specific
    Last Post: April 27th, 2010, 04:15 AM
  2. FJO wideband install
    By sinr98 in forum General
    Last Post: April 27th, 2010, 03:03 AM
  3. Side effects
    Last Post: May 21st, 2007, 01:25 PM
  4. Getting ready to install my wideband...
    By Loudmouth LS1 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2007, 04:21 PM
