Results 1 to 2 of 2
Thread: first diesel tune
    Default first diesel tune
    Starting on my first diesel tune this weekend. the truck is my buddy's 04. doing a little reading but i'm very confused on the setup of the ecm's i kinda know the basic stuff to do but i don't know how to incorporate them in to the actual tune. looking to turn off the egr, add fuel and injector pulse with a bit with higher fuel rail pressure, and tweak the timing slightly? i know you can change the way the tranny locks for a better bite at part throttles, but that right now is way above the learning curve unless its the same concept as a gasser.
    Any hints or maybe even certain posts to read up on would be greatly appreciated.
    Thanks,
    Jake
    Sep 2006
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
  1. jump from gas to diesel....
    By 0rion in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 7th, 2010, 05:23 AM
  2. New to Diesel and EFI live
    By Fueler in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 29th, 2009, 06:47 PM
  3. diesel guy tryin to tune a gasser
    By drdiesel in forum Gen III V8 Specific
    Last Post: September 11th, 2009, 05:02 AM
  4. air to fuel on diesel
    By ZL1Killa in forum General (Diesel)
    Last Post: September 14th, 2007, 04:26 AM
