Results 1 to 5 of 5
Thread: Crank sensor relearn 97 chevy truck
    Lifetime Member Gregs's Avatar
    Sep 2008
    Default Crank sensor relearn 97 chevy truck
    i was wondering if efilive supports the crank sensor relearn on a 97 chevy truck with the 350 motor
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Aug 2006
    No. EFILive will not do a relearn on the 96-97 trucks. EFILive V2 will do the relearn on the 98-2000 Black Box PCMs. The 12200411 PCM can be installed into your truck and the V1 or V2 will do the relearn on that.
    Jeff
    Mar 2009
    Quote Originally Posted by Lextech View Post
    Jeff
    I've tried it on a 98 and it would not do that one either.
    Aug 2006
    HHMMM, I was under the impression that V2 would do the 98 and up Black Box PCM crank relearn.
    Jeff
    Sep 2008
    ok, thanks. i was asking about a buddy's truck. I'll let him know
    Stock for now
  1. crank relearn??
    By 2004gmc in forum Lounge
    Last Post: July 30th, 2021, 12:24 PM
  2. E38 Crank Position Sensor Relearn
    By hapnermw in forum Gen IV V8 Specific
    Last Post: May 2nd, 2009, 04:58 PM
  3. E38 5.3 LMG Crank relearn
    By harascho in forum Gen IV V8 Specific
    Last Post: December 4th, 2008, 08:04 AM
  4. Crank Relearn
    By mk6racer in forum Gen III V8 Specific
    Last Post: May 15th, 2008, 11:05 AM
  5. crank relearn on 97 L31 vortec truck?
    By sean3393 in forum General
    Last Post: July 31st, 2007, 06:29 PM
