Results 1 to 10 of 11
Thread: help truck wont start!
    Mar 2010
    Default help truck wont start!
    I attemped to do a full reflash on my truck then install a new tune, I get an error code stating that the serial number on the ECM is 0000000000 and to do a full reflash and EFI Live will assign a new serial.
    We did this and it assigned the new serial and said it was completed successfully, after this truck still wouldnt start, we attempted putting in the dsp5 tunes that we pulled out of the truck and it still says the serial 000000000 error. What should I do next? Earlier in the day we used the "Program PCM with current calibrations and operating system" function a couple times, could this have created the problem? Please Help.
    First, what version of the software are you using? If you're not using the latest (7.5.6 build 107 and V8.1.2 build 87) then download them from this link: EFILive V7.5.6 build 107
    What truck is this on, I know its a Duramax but LB7, LLY, LBZ, or LMM? Make sure you update the firmware on your V2 as well.
    Mar 2010
    it is an 02 lb7 and i have a v1 if that makes any difference and i have version 7.5 does that mean it is the newest one or are there different 7.5s? thanks for the help
    Mar 2010
    it is version 7.5.5 build 88 i also have a dsp5 switch if that helps i am new to efi live so i dont know what will affect it any input would be much appriciated thanks
    Mar 2010
    can i just plug in my other ecm that i got from the wreckers for now so i can at least drive it again or will that work? i have not even tried that ecm yet because i was not sure if i could just plug it in to my truck and it would work or not? do you have to get them flashed ny the dealer or anything?
    Since you have a V1 you just need to update to the latest 7.5.6 release I linked to above.
    You will have to at least do a security relearn and maybe a VATS relink on your new ECM before it will work.
    Once you have updated, try it again. I know for LBZ/LMMs you cannot read DSP5 tunes out, I believe LB7 and LLYs you can. Maybe try just reflashing the original (stock) tune back in.
    Mar 2010
    i dont have the stock tune all i have is the dsp5 that came with it and nicks tune library is there a place to find a stock tune for it so i can try that?
    Unfortunately GM's TIS system had a habit of wiping out some critical data on early LB7's during dealer updates. It might be possible your truck had this happen at some point.
    Did you at any point read out what was in the truck prior to programming it?
    Mar 2010
    yes i did read the calabration data from the ecm before tring to install the new tune i thought you had to do that?
    Did the VIN etc look ok in the file? usually when the ECM is corrupted this info is jibberish.
  1. 'Race truck' wont start..
    By nonnieselman in forum Gen III V8 Specific
    Last Post: January 12th, 2010, 08:33 AM
  2. sterio swap and truck wont start
    By pullincrazy88 in forum General (Diesel)
    Last Post: September 2nd, 2009, 02:42 AM
  3. help truck wont crank?
    By dpduramax in forum Duramax LB7
    Last Post: May 12th, 2009, 06:06 AM
  4. Truck wont shift and getting a U0100
    By heathgu in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 20th, 2007, 01:39 PM
  5. Help Truck Wont Start - Flash messed up somehow?
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 12:17 PM
