Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: EFILive V7.3.0 Released
    Default EFILive V7.3.0 Released
    Download here:
    http://www.efilive.com/downloads/downloads_7.html
    Please post any issues with the download or installtion in this thread.
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Exciting! We love a new, clean install.
    Thanks,
    Bruce
    PowrMax Performance
    100 mm PowrMAF
    Oct 2003
    Me, too!
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Jan 2005
    I've been needing this for a while!
    Check the lounge. A fellow over there was having install trouble with the msi
    Oct 2005
    hmm, looks like LC-1 calc and ben pids are slightly off in the sae-generic file.
    The numbers/discriptions dont match the formula's etc.
    # Innovate LC-1 WBO2
    *CLC-00-934
    V 0.0 5.0 .1 "{EXT.AD1}"
    AFR 10.0 20.0 .2 "({EXT.AD1}*3)+7.35"
    *CLC-00-935
    factor 0.0 2.0 .1 "{CALC.AFR_LC11.AFR}/{GM.AFR}"
    *CLC-00-936
    V 0.0 5.0 .1 "{EXT.AD2}"
    AFR 10.0 20.0 .2 "({EXT.AD2}*3)+7.35"
    *CLC-00-937
    factor 0.0 2.0 .1 "{CALC.AFR_LC12.AFR}/{GM.AFR}"
    CALC.AFR_LC11 F520 CLC-00-932 "AFR,V" O2-Wide "Wide Band AFR 1 - LC-1"
    CALC.BEN_LC11 F521 CLC-00-933 factor O2-Wide "Base Efficiency Numerator 1 - LC-1"
    CALC.AFR_LC12 F522 CLC-00-934 "AFR,V" O2-Wide "Wide Band AFR 2 - LC-1"
    CALC.BEN_LC12 F523 CLC-00-935 factor O2-Wide "Base Efficiency Numerator 2 - LC-1"
    2014 VF SV LS3 Maloo.
    Quote Originally Posted by ringram
    Good catch, my bad :(
    Guess a patch is due out anytime now...
    Oct 2005
    Another thing I noticed was that on one PC the install didnt overwrite the custom cals. I had to copy them over the top. The stock ones got written ok.
    This was doing an over the top upgrade over pre 7.3.
    Maybe was my bad, but I dont think so.
    I guess that comes down to a "paranoid installshield algorithm" that says, if a file exists (and it is not part of any previous install), then don't overwrite it.
    The custom *.cals were not part of any previous install (i.e. V7.2.2). They were only ever made available as downloads from the web. To the installer, they appear as "foriegn" files - not to be overwritten.
    Another possibilty:
    Did you happen to copy the *.cal or *.tun files from one PC to another using a CD? If so they can get marked as "Read-only" which may cause the installer to not overwrite them.
    Lifetime Member mistermike's Avatar
    Dec 2003
    I edited my SAE_Generic.txt file to fine tune my LC-1's. I've obviously done manual installs up to this point. Should I rename my current file to preserve it before running the install routine? Does the installer automatically do all the .cal and .tun files?
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Quote Originally Posted by mistermike
    If you have changed sae_generic.txt then save it and copy it back after the install - it will be overwritten during the install.
    I recommend deleting (or backing up and then deleting) all the *.cal files and the custom *.tun files (don't accidentally delete all your normal *.tun files) prior to installing. That way you know the new ones will be installed.
    If you've already installed, then you can just delete them anyway and re-run the install and select [Repair] to re-install the deleted files.
  1. YEAH! V2 is released!!!!
    By wait4me in forum FlashScan V2
    Last Post: November 21st, 2006, 04:42 PM
  2. When V2 is released Question?
    By kbracing96 in forum Purchase and Shipping
    Last Post: March 6th, 2006, 03:08 PM
  3. Is 7.2.3 going to be released by Saturday?
    Last Post: August 14th, 2005, 08:47 AM
  4. Pricing on Upgrade for 98s when released?
    By dlandsvZ28 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 13th, 2004, 11:41 AM
