Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: EFILive V7.3.0 Released
  1. #11
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    I was just setting up the black box to log data from my friends 98 Firebird and we kept getting weird data. I selected Inj. Duty Cycle Bank 1 & 2 but was getting Inj. 5 & 8 Duty Cycle or Inj. 3 & 6 Duty Cycle. These PID's are not valid PID's for this vehicle. I was wondering if this was related to the error in sae_generic.txt for the LC-1.
  2. #12
    There have been problems found with the sae_generic.txt and gm_enhanced.prn files. They are most likely the cause of that problem. They will be fixed and new files will be posted for download asap.
  3. #13
    Oct 2005
    Yeah I tried the copy older sae_generic trick yesterday, but as you say the gm.._prn file didnt match, so that was a no go.
    Also custom .cals were from download not the cd, so I guess its the foreign file issue.
    2014 VF SV LS3 Maloo.
  4. #14
    A new, updated sae_generic.txt file has been made available here:
    http://www.efilive.com/downloads/sof...ae_generic.txt
    It fixes the CALC PIDs problems discussed in this thread.
  5. #15
    Sep 2003
    Default Error with V7.3 Public Install?
    Paul,
    I just installed V7.3 public (your latest release) over a beta 7.3 V & also copied the additional sae_generic.txt file as per your instructions but neither EFILive or Flashscan will fully launch due to errors. The error messages are:
    EFILive - "ERR_DUPLICATE/109, Duplicate *PRNname:GM.MAP"
    Flashscan - "Duplicate *PRNname:GM.MAP"
    Appears a PRN duplication is causing the problem with both.
    Didn't see any comments on your downloads page about needing to do a clean install but could this be the issue?
    Thanks,
    Acer
  6. #16
    The duplicate GM.MAP problem was fixed over a month ago. For some reason you may still be using an old version of gm_enhanced.prn.
    The file date on gm_enhanced.prn should be Nov 15, 2005 12:00am, please make sure that is the file that you have here:
    \Program Files\EFILive\V7\Configuration\gm_enhanced.prn
    The two files in question:
    \Program Files\EFILive\V7\Configuration\sae_generic.txt
    and
    must both be from the latest V7.3.0 download available on our web site.
    Additionally, the
    \Program Files\EFILive\V7\Configuration\sae_generic.txt should be updated with the file listed in this thread.
  7. #17
    Sep 2003
    Thanks Paul, updating the gm_enhanced.prn file solved the problem.
    Acer
  8. #18
    Dec 2004
    I had some problems extracting v7.3.0 last night from the downloaded zip file. The problem appears to be related to the default Windows XP zipfile application.
    I tried the same deal today using another machine on a Windows 2000 platform. This time I used Winzip which extracted the files without drama... and v7.3.0 installed OK too.
  9. #19
    Dec 2004
    Problem 1:
    Having problems installing v7.3.0 (EFILiveV730_308_449_320.zip) on my laptop... get the error "Unrecognised PCM" dialog when invoking Tuning Tool. What would be the reason for that? I have custom file 1290001 and upgrading from v7.2.2.
    Problem 2:
    Tried to install the updated self extracting file, EFILiveV730_309_451_324.exe, in the hope that it might fix Problem 1 but get CRC error during the install.
  10. #20
    Quote Originally Posted by SSbaby
    Problem 1:
    Check that the *.cal file matching the operating system exits. In your case, check that this file exists:
    \Program Files\EFILive\V7\Calibrations\1290001.cal
    If it does not exist, re-run the installation and select repair.
    If it does exist, delete it (actually it would be a good idea to delete all *.cal files in that folder) and then re-run the installation and select repair.
    Problem 2:
    Have you checked the downloaded file using the supplied MD5 checksum?
    See section "EFILive Download Verification" just below the V7.3.0 download.
  1. YEAH! V2 is released!!!!
    By wait4me in forum FlashScan V2
    Last Post: November 21st, 2006, 04:42 PM
  2. When V2 is released Question?
    By kbracing96 in forum Purchase and Shipping
    Last Post: March 6th, 2006, 03:08 PM
  3. Is 7.2.3 going to be released by Saturday?
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 14th, 2005, 08:47 AM
  4. Pricing on Upgrade for 98s when released?
    By dlandsvZ28 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 13th, 2004, 11:41 AM
