Originally Posted by
SSbaby
Unfortunately, not much luck there, Paul. I deleted all the cals and selected repair option... same deal. :(
Can you delete the \My Documents\EFILive\V7\User Configuration\cal_link.txt file and re-run the install and select repair.
It's a long shot, but a misplaced ; character in that file can cause the error you are seeing.
Failing that a complete fresh install of EFILive may be required.
To do that:
1. Uninstall the current EFILive installation using Windows->Control Panel->Add/Remove Programs.
2. Rename \My Documents\EFILive\V7 to \My Documents\EFILive\V7_OLD
3. Rename \Program Files\EFILive\V7 to \Program Files\EFILive\V7_OLD
4. Start->Run, enter Regedit click OK
5. Find the key: \\HKEY_CURRENT_USER\Software\EFILive\V7 and delete it, which will delete everything it contains.
6. Re-install EFILive from the downlaoded file.
7. Copy your logged data files and tuning files from the V7_OLD folders to the newly isntalled V7 folders. And PID selection files and dashbaord files and any other files that you want to "retain".
7. Keep the V7_OLD folders around for a while (or just make a copy of them onto a CD) in case there are files in there that you want to keep that you do not realise just yet.
