Results 1 to 8 of 8
Thread: LS2 Locked. Tuner says no way
    Lifetime Member Chalky's Avatar
    Sep 2003
    Default LS2 Locked. Tuner says no way
    A friend with an LS2 had it tuned by reputable shop. I beleive tuner used LS2 Edit. I tried to download tune twice after car had been to tuner. Both times EFILive tells me the tune is locked. Funny thing is I did modify a tune from this same tuner on an E38 07 Z06 and had no trouble downloading, modifying and uploading changes.
    If a tuner had locked a tune in the past, could they supply the key and could it be used in EFILive to unlock the tune?
    Is there anything unusal about LS2 TUNED ecms that creates issues with downloading tun file?
    2015 Z06 A8
    Dec 2007
    Apparently LS2edit does lock ECM and TCM tunes by default though this can be changed to not lock: tuner can simply change this option. No idea if they tell you the key they use.
    Jan 2005
    This seems to be a legitimate LS2Edit issue. Every ECM I've come across that has been tuned with Edit has been locked-- by the software, not by the user. I don't use that junk, so I'm not sure if or how the problem can be eliminated.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Sep 2003
    Appreciate the replies. I know LS2Edit originally defaulted to loicked and caught some tuners by surprise or so they claimed.
    At this point, car is going back to original tuner for final tuning.
    2015 Z06 A8
    Quote Originally Posted by Chalky View Post
    As does HPTuners from what I have seen. Locked ECM's where the tuner swears black and blue they never choose to lock anything.
    Sep 2003
    Default Happy ending!
    Come to find out, ECM in 06 C6 Corvette is E38. I was trying to download using E40 processor.
    Problem solved.
    2015 Z06 A8
    Oct 2004
    That would definitely do it mate
    Andrew
    EFILive Crew
    Sep 2003
    Quote Originally Posted by Tordne View Post
    What's new?
    2015 Z06 A8
  1. 5.3 tuner?
    By Zebler in forum Gen III V8 Specific
    Last Post: July 11th, 2010, 06:53 PM
  2. PCM Locked by a HP-Tuner
    By Spindoctor in forum Gen III V8 Specific
    Last Post: June 6th, 2008, 09:57 AM
  3. Had hp tuner now want to use efi is this ok?
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: May 24th, 2006, 01:16 PM
  4. I wonder how the tuner did this......
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2005, 11:15 AM
