Results 1 to 10 of 18
Thread: can someone tell me what I'm missing here?
    Jun 2004
    Default can someone tell me what I'm missing here?
    I'm making a calc. pid and I'm missing something. It's not showing up in the systems list. I've read the stickies and I'm a little confused on the PRN number because one of the stickies says you can use F000-F3FF but the help file in the scanner says to use F600-F6FF but I don't think that's my problem. I'm missing something else I think.
    I'm making a PID to calc. boost from the MAP sensor.
    Nov 2006
    Try this:
    PHP Code:
    *CLC-00-001
    psi
    -30.0         30.0          0.1  "({SAE.MAP.kPa}*0.145038)-14.5038"
    CALC.REALBOOST          F001     CLC-00-001          psi              Performance      "Boost"
    LC-1 WBO2
    Jun 2004
    still can't get it to show up in the list. I can't figure out what I have wrong. psi is already defined in the generic file so I don't have to list this again under units do I?
    Nov 2006
    The units are case sensitive you had psi in capitals.
    You also had {SAE.MAP.KPA} in the expression,
    it should be {SAE.MAP.kPa}
    The above works for me.
    LC-1 WBO2
    Jun 2004
    I got it.....don't want to tell you what was wrong though. It's the same as it always is....something simple and stupid that will cost me hours of frustration. I had the user config folder copied to a different directory for when I did/do upgrades. I was changing that calc.pid but not moving it to the my documents/user config directory. Moved it over and now have a functioning boost gauge in the dashboard view.
    Also, add an extra 2 blank lines at the end of the file (otherwise the description gets truncated).
    I like to make the xxx in Fxxx and CLC-00-xxx the same (as shown by mr.prick's example above), it makes it easier to keep track of all the equations (my $0.01).
    Glad you got it...
    Jun 2004
    thanks for your help and the tips......as soon as you pointed out the caps in kPa I thought that was it but even if I would've had that right it was still in the wrong directory. I also saw you called it F001 and then figured out why. I was kinda confused on the available range for that so I was trying to go by the help file and start at 600.
    Also note that to get boost in psi you can do it in a simpler manner: "{SAE.MAP.psi}-14.5038"
    i.e.
    Code:
    *CLC-00-001
    psi           -15.0         30.0          0.1   "{SAE.MAP.psi}-14.5038"
    To have boost in both psi and kPa do this:
    Code:
    *CLC-00-001
    kPa          -100.0        200.0          0.1   "{SAE.MAP.kPa}-100.0"
    CALC.REALBOOST          F001     CLC-00-001            "psi,kPa"               Performance      "Boost"
    # leave 2 blank lines at the end of file
    Then in a chart or gauge, you would have booth CALC.REALBOOST.psi and CALC.REALBOOST.kPa available.
    (As you have found, watch the spelling of kPa).
  1. Another missing PID
    By gmh308 in forum Black Box Logging
    Last Post: September 29th, 2009, 01:00 PM
  2. Missing VIN
    By 99STEPSIDE in forum FlashScan V2
    Last Post: February 11th, 2009, 03:30 PM
  3. E38 Missing tables? Or I'm missing something?
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 7th, 2009, 03:28 PM
  4. PID's Missing or am I missing something
    By dperry in forum Duramax LLY
    Last Post: March 1st, 2007, 03:15 PM
