Results 1 to 4 of 4
Thread: LS1 engine modified, how off is the tune?
    Nov 2008
    Default LS1 engine modified, how off is the tune?
    I have in a hurry rebuild my Procharged LS1 Volvo 242 engine because the car is going to a car show. http://www.hocky.se
    Engine prior to rebuild:
    Stock LS1 from a 1999 Camaro SS
    Procharger at 5-6PSI
    3 bar MAP
    No MAF
    Engine after rebuild:
    Procharger at ? PSI (maybe 7 if i am lucky)
    9.0 in compression
    Lunati 550/550 223/223 camshaft
    New rings and bearings of cource
    The engine is fired and was running good at idle.
    I have not time to retune the engine before the car show :(
    Anyone have any points on how off the tune is and how much.
    Post the tune, someone who knows the LS1 PCM better than I can shed some light. With that cam you might experience some idle issues, but Id be more worried about the much lower compression.
    Are you going to run it at the car show, or just drive it there? If you're going to run it, Id get your laptop and FlashScan on it to start reworking the tune.
    Cool car btw!
    Nov 2008
    I have the tunes on my work computer, maybe I can post a tune tomorrow.
    I will not race the car but I had plans driving there and you know how it is with the right leg
    I really hope the combination will work, cam, compression and procharged.
    I friend had the cam lying and I thought putting the stock cam in would be a shame...
    Thanks!
    Nov 2008
    Here is my cal file.
  1. new engine, I need help with my tune
    By pdasterly in forum Gen III V8 Specific
    Last Post: December 17th, 2009, 02:56 PM
  2. Modified Tune For Reference Please
    By Dennis93TA in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 4th, 2007, 03:57 AM
  3. I need a stock or modified 2002 5.3 silverado tune file
    Last Post: July 24th, 2006, 02:36 PM
  4. Need stock or modified 2003 5.3 Silverado tune file...
    Last Post: July 17th, 2006, 01:50 AM
  5. Modified Tunes
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2006, 08:22 PM
