Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: d2903 factory set at 10?
  1. #31
    That appears to be a regular LS1 99-02 512kb PCM, so yes you can flash a 2002 OS in and use a COS.
  2. #32
    Member Ritch's Avatar
    Feb 2007
    ____________________________
    1999 GMC, rcsb, 2wd, 5.3, XR275HR-12
    Radix magnacharger mp112
    Long tubes true duals, $L60E
  3. #33
    Feb 2007
    Warning flashing a truck os12212156 that had a 4l80 will not work well
  4. #34
    Hi Ritch,
    TIS reads zero always.
    No shifting above 2nd.
    TSHIFT pattern is toggling between 2WD and 4WD.
    Looks like is applying the TCC in 2nd but TCCSLIP is not dropping down.
    Some things are all wrong... was this a full flash or a cal-only flash.
    Can you flash it back to original...?
    Can you post the tune from the truck prior to flashing, and the tune flashed in.
    That PCM might not be compatible.
  5. #35
    Feb 2007
    I did flash the original back in. I had copied an OS with 4L80 trans, and 4x4 apparently. I'm halfway through converting a 2002 Camaro 5.7 A4 bin. Get back to it tomorrow.
    Edit: The Camaro tune cause issues with theft,gear selection and TCC upshift. Now using 2002 truck OS much more successfully
  6. #36
    Feb 2007
  7. #37
    Quote Originally Posted by Ritch View Post
    Was this PCM previously 4L60E...?
  8. #38
    Feb 2007
    Joe, I assume it was because 4L80 is in the Vehicle Identifiers under Calibration. I could change the VIN, but the rest stays the same.
  9. #39
    Sanity check: you did do a full flash...?
  10. #40
    Feb 2007
    yep, did the full flash with 02 camaro, 02 truck and 01 Tahoe. The truck and Tahoe ones caused the TFMS to drop to zero when throttle was zero.
  1. Link to GM T43 factory calibrations?
    By C6Guy in forum Gen IV V8 Specific
    Last Post: May 14th, 2010, 08:37 AM
  2. P0757, D2903 & D2904 tables???
    By Mr. P. in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 7th, 2009, 12:58 PM
  3. PLEASE...Need '08 Z06 factory cal
    By KAZ MotorSports in forum E37, E38 & E67 PFI ECM's
    Last Post: March 30th, 2008, 12:58 PM
  4. Is The Factory Computer Ever Too Small?????
    By rustynuts in forum Gen III V8 Specific
    Last Post: January 18th, 2008, 07:35 PM
  5. Factory Tune File wtd
    By johnv in forum Gen IV V8 Specific
    Last Post: August 25th, 2007, 04:05 PM
