Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Auto VE trouble (yes another one)
    Mar 2010
    Default Auto VE trouble (yes another one)
    I am working on my first tune using EFIlive and have been trying to read as much as possible. Fortunately/unfortunately there is alot (actually an overwhelming amount) of information on this forum, and I am not sure what I am doing wrong.
    I have access to a load bearing dyno that I have been using to do the auto VE process.
    Car being tuned: 2001 Camaro
    LSX block bored out to 427
    Patriot Heads
    82mm throttle body
    Stock MAF
    Fast 36lb/hr injectors
    Stock fuel pump with racetronix "hotwire" at 65PSI(?)
    Base tune purchased for motor break-in
    When I started with his car in the Auto VE process, it was showing in excess of 20% lean (BEN's of 1.22) even with the 15% for the Auto VE process. I didn't run it very long like this and added the 20% across the board. BEN's started showing less than 10%. After this point the BEN's have been very erratic and seems to be over compensating when I multiply to the B0101 table. After Struggling with this for several iterations, I decided to just hand smooth the table to get rid of any severe peaks/vallys, and most of the BEN's were pretty close. I did some small adjustments and the BEN's went back to 1.12 range. I don't understand why they are jumping around so much.
    I am using a PLX WBO2 from the dyno which I haven't had any issues with erratic readings (I think it might be reading rich)
    Our plan was to get a fuel pressure gauge and try to watch what it is doing during the tuning cycles. Here are a couple of the logs if someone could point me in the right direction. I am sure there will be requests for more info so please let me know if you need any more detail.
    Nov 2006
    Which injectors are those?
    It looks like just the IFR was changed, the offsets should be changed too.
    The PLX output of ({EXT.AD1}*2)+10 is for EQ1=14.7 and does not match perfectly to {B3601}.
    That may be one reason why BEN is "over compensating"
    Setting {B3601} to 14.681005 will get it closer to the PLX PID or
    you can make a calc_pid to match {B3601}
    Lambda output for the PLX is ({EXT.AD}*0.1360)+0.680 if you want to go that route.
    I would set {B3605} to 1.00EQ from 158F down and set {B3618} to 1.176EQ
    This way commanded AFR does not doesn't hop around solely on MAP and
    you can more easily control when AFR is to be richer.
    LC-1 WBO2
    SCP, welcome to the forum...
    Do you have FlashScan V1 or V2...?
    Set these to in-range values:
    Out of Range calibration summary: 12:21:36 am, Friday Apr 02, 2010
    Engine Calibration.AIR Pump
    {B0203} AIR Pump Coolant Temp Disable, was out of range when loaded.
    Transmission Calibration.CARS/CAGS
    {D0407} CARS Coolant Temp Enable, was out of range when loaded.
    Set B3618 to a richer value 1.176EQ (AFR 12.44), like mr.prick said... and watch out for knock...!!
    Also set B3609 to zeros... (this time is in addition to B3608).
    Are you applying a transient filter to the BEN map...?
    Can you test your PLX by running a known stoich AFR...?
    Does car have NBO2 sensors...? If so, then enable B4206 and see if the WB AFR converges on 14.63 (and then remember to disable B4206 before proceeding).
    Also log these:
    GM.DYNCYLAIR_DMA
    GM.DYNAIR
    HO2S11 (if car has them)
    HO2S21
    Yes, see what rail pressure is doing with different loads.
    This is still a returnless system, right...?
    In log 11, the wideband AFR is not following commanded AFR at all... something is wrong...
    Mar 2010
    Quote Originally Posted by mr.prick View Post
    Injectors are FAST brand. What do I need to adjust the offsets to?
    I can adjust {B3605} to match closer.
    I understand, but why does the auto VE say to command stoich in the {B3618}?
    Thanks for the input Mr. Prick
  1. Trouble Communicating with E38 ECM
    By philip.long in forum E37, E38 & E67 PFI ECM's
    Last Post: January 25th, 2009, 09:33 AM
  2. Looking for help, having some VE tuning trouble
    By Whippled 496 in forum Custom Operating Systems
    Last Post: January 15th, 2007, 06:35 AM
  3. DMA Pid trouble
    By MoTruck in forum General
    Last Post: December 29th, 2006, 11:47 AM
  4. Trouble connecting
    By ahall1 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2005, 11:30 AM
