Results 1 to 4 of 4
Thread: recordes only up to 3000 frames now?
    Sep 2008
    Default recordes only up to 3000 frames now?
    question, why or what did I do that only allows 3000 frames?
    In scantool, go Edit->Properties->Logging and set Frames (x1000) to a larger value like 100.
    Sep 2008
    thank you, so looking at my log...can you see why it seems to not have any power at a WOT launch? untill it can has climbed up to a higher RPM.
    I only had a chance for a quick look at your files...
    No power initially during WOT launch:
    - there seems to be a flat spot in the TP waveform... I can't tell if you held the throttle steady at 34.9%, or what...?
    - then, after that, throttle goes to 100% but no enrichment shows up at all;
    refer to the first pic;
    Look at B3618 and B3647: what happens if you go WOT at low RPM...? (AFR is going to be too lean)...
    Do this:
    - make the high MAP column of B3647 sufficiently rich for boost for all RPM's (richer than 12.6 is my understanding),
    - make B3618 sufficiently rich all the way across.
    Also note this:
    - running out of injectors (183% DC),
    - insufficient AFR for boost;
    see second pic.
Name:	Holding Throttle.png
ID:	7525   Click image for larger version.
Name:	Exceeding Injecors.png
  1. Can't display more than 99,000 frames
    By XLR8NSS in forum General
    Last Post: July 11th, 2008, 07:47 AM
  2. How to get to the frames you want
    By kjhansen in forum EFILive V4
    Last Post: April 11th, 2008, 02:25 PM
  3. 3000 stall will not lock up
    By woody69 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 24th, 2007, 09:12 AM
  4. No frames logged??
    By Garry in forum Black Box Logging
    Last Post: July 7th, 2006, 02:21 PM
  5. AC on and it idles at 3000+ WTH?
    By Darkness in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2006, 02:46 PM
