Results 1 to 10 of 10
Thread: What are your MAP readings?
    Jul 2007
    Default What are your MAP readings?
    Looking for MAP values at idle for both STOCK AND AFTERMARKET cams.
    If your cam is not stock, please state the specs if known.
    For example, my stock cam was around 45kpa, my aftermarket (in sig)
    72kpa. Stock 03Z cam in a 12:1 416, 29kpa.
    07 Silverado DMax Classic
    Nov 2006
    I don't know what my cam specs are in my 383 but MAP @ idle averages 45.6 kPa and
    85 kPa max @ mile high altitude.
    LC-1 WBO2
    Jul 2008
    Stock: ? ..To long ago..
    Aftermarket Cam: 228/232 110+2 (10 degrees of overlap): ~ 48 kPa at 5400'..equates to ~ 66 kPa at sea-level.
    Idle: 800 RPM's (M6)..24 degrees base timing..
    Jul 2007
    MAP readings will vary widely with the chosen idle spark settings. For example...
    220/224 @ 114
    Code:
    Base Spark     MAP kPa
       22'         39
       20'         45
       16'         46
       15'         47
       13'         48
       12'         50
    Simon.
    Compared to the stock cam
    here's mine
    224/228 598 thou lift 112 lobe
    14 deg base idle timing
    60 kpa at 800 rpm idle (operate temp)
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    2001 stock LS1 (196/207 116):
    36 kPa
    564 rpm
    Timing 26°
    ECT 194°F
    MAF 6g/s
    thru stock exhaust manifold
    I can look thru some logs to see what difference LT headers make... or I can put them back on soon (I also got LS6 heads/cam I can put on).
    Jul 2008
    ZO6:
    Nice sound clip!!!
    220/224 @ 114
    Code:
    Base Spark     MAP kPa
       22'         39
       20'         45
       16'         46
       15'         47
       13'         48
       12'         50
    Simon.
    Swingtan thats an interesting association you show with Base Spark and MAp kPa. I probably did not realize it was that dependent on base spark. I ended up with the 20-24 base spark at Idle, but your chart does make a lot of sense.
    Joecar, it might be interesting to see how your car may do with some additional mods. There are times I wish I had the bucks to have one LS1 modded, and one completely stock. Sometimes I forget how nice these cars are just totally stock. Though I must say I would have a hard time without an aftermarket exhaust and headers.
    I know being in California it probably is not easy. But even a 'milder' cam and a little head work can add to the driving experience. I ran a 'smog' cam 220/220 114 for awhile. I actually liked that cam. Mod fever is hard to break though!
    OP, sorry to divert. Thats a nice 1/4 mile time you have. Is this your 'street-car', or just track?
    Jul 2007
    ZO6:
    I recently yanked the license plates off of it, then later changed my mind when reality set in that I couldn't drive it this summer. I guess that defines it as a mostly strip, some street.
    I'm adding a 255/263 cam and turn downs soon. (to experience a June race that is coming up; it will get trailored for that). I'll post up a WMV when available.
    Thanks for the data guys. I am just interested in how diff cams and LSAs affect vacuum.
    2000 LS1
    Thunder Road TR230 Cam 230/224 111)
    57 kPa
    826 rpm
    Timing 21°
    ECT 85°C
    MAF 9g/s
    Tubular manifold, 2.5" Duals
    Rgds
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    Mar 2005
    excellant illistration! I often change the in gear spark by 3 to 4 degrees lower timing so you get a nice fat off beat when sitting at the lights yeah baby
    220/224 @ 114
    Code:
    Base Spark     MAP kPa
       22'         39
       20'         45
       16'         46
       15'         47
       13'         48
       12'         50
    Simon.
    "Just a tune > yeah right !!!! "
  1. Lc1 wrong readings.
    By tor1965 in forum General
    Last Post: May 4th, 2010, 09:47 AM
  2. MAP Readings in a 5.3 Vortec
    By RacerChris in forum Gen III V8 Specific
    Last Post: February 26th, 2009, 01:18 AM
  3. Please Help Readings Gone Crazy
    By nm2769 in forum Black Box Logging
    Last Post: May 21st, 2008, 04:38 AM
  4. Can you smooth out the AFR readings in FS?
    By Redline Motorsports in forum General
    Last Post: October 14th, 2006, 01:27 PM
  5. AFR readings low through EFI
    By Chalky in forum General
    Last Post: May 18th, 2006, 02:24 PM
