Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: cant get stock tune off truck
    Junior Member browneflatwork's Avatar
    Nov 2009
    Default cant get stock tune off truck
    i am trying to tune a 05 lly, it keeps telling me bootloader rejected check cables no communication from ecm.....it starts to read and wont go past getting status........i tried to pull radio fuse info fuse all other aftermarket electronics area removed have just got a new lisense and updated my efi what eles could it be????? thanks
    EFI....SC IV,fass 150,sleeves, MBRP 4in TB,afe intake, shimmed rail, blocked egr,auto meter c2 gauges, home built trac bars,
    Nov 2009
    i also unchecked the high speed and tried using alt keys, still would not work
    Mar 2009
    Check for a blown cigarette lighter/power port fuse because it also powers the OBD port and if it's dead a scanner can't communicate.
    That one has gotten me a couple times on the GM trucks.
    Nov 2009
    I checked aux fuses and all other cig fuses they are good, the conection to my laptop is fine scanner comes on, and also when I plug just into the truck it will come on,
    Hi browneflatwork,
    Can you copy/paste the text that shows up during your attempt into this thread...
    Thanks,
    Joe
    Nov 2006
    Is the scan tool connected while using the tune tool to read/write to the PCM?
    It should not be.
    LC-1 WBO2
    Nov 2009
    the text says......Connection to ecm has been lost please check all cabels and conections
    Nov 2009
    i switched usb ports on my computer than got a Bootloader rejected :Reason no response from ECM
    Are you selecting the correct Controller...?
    I pm'd Tech Support.
    Nov 2009
    lly ecm.....truck is an o5 8th digit of vin is 2.........i also have a 05 lly and it tunes reads just fine no problems.....this truck aftermarket radio i pulled both radio fuses tried with and without info fuse in still nothing
  1. Help Please**** LLY With A LBZ Computer Stock Truck
    By Duramax 6.6L in forum Diesel
    Last Post: June 2nd, 2010, 11:48 AM
  2. Stock truck idle problems after flash..?
    Last Post: August 28th, 2009, 08:07 AM
  3. Tune for 07 6.0L truck?
    By 07.5duramax in forum Gen III V8 Specific
    Last Post: February 25th, 2009, 04:54 PM
  4. Truck Tune
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: May 13th, 2007, 01:25 PM
  5. Help with tuning stock truck
    Last Post: February 23rd, 2007, 09:27 AM
