Results 11 to 20 of 27
Thread: cant get stock tune off truck
    Oct 2004
    The late model LLY Duramax vehicles actually use the same controller as the LBZ models. Have you tried selecting the LBZ controller and seeing if you ca read?
    Andrew
    EFILive Crew
    Junior Member browneflatwork's Avatar
    Nov 2009
    i just tried to use the lbz ecm and still will not pull stock data..... it still says check cabels and no comunication from ecm......i went through every fuse in truck and under hood just in case every fuse is good only fuses that are out are radio and info and i have tried with info in and out......
    EFI....SC IV,fass 150,sleeves, MBRP 4in TB,afe intake, shimmed rail, blocked egr,auto meter c2 gauges, home built trac bars,
    Nov 2009
    and like i said before i have a conection between the v2 and my laptop and also the v2 and the truck when plug into obo port....... tried pulling stock info with lly and lbz ecm......at one time it wen tpast gettin status but it stopped adn said that the ecm my not have a valid calibration EfI live can still read through the damange calibration or reflash a new calibration
    Mar 2009
    Can you at least check codes or monitor data with the scan (using pass-thru)?
    Oct 2004
    Hmm..
    Sounds like you have checked the cigarette lighter fuse as suggested earlier.
    If you connect V2 only to the OBDII port (not connected to laptop) does the V2 boot up normally?
    As Big Mike asks; are you able to scan/log at all?
    I sounds electrical to me if I was to hedge a bet.
    Andrew
    EFILive Crew
    Nov 2009
    yes it boots up like normal....i have checked fuses over and over
    Do you happen to have an alarm? I had a friend a couple weeks ago go through the same thing for hours and he ended up having to disconnect the after-market alarm and pull the radio fuse. After that he had no problems.
    Nov 2009
    no aftermarket alarm....no lift pump or anything it has aftermarket radio that is it......radio fuses are pulled i keep trying and trying different things still nothing keeps tellin me no respons from ecm......i got a damanged calibration msg one time it said it can read through it adn reflash i tell it to keep reading and then 2 second later it bootloader rejected no response from ecm......
  9. #19
    Mar 2009
    Disconnect the batteries for at least 10 minutes and try again.
  10. #20
    Nov 2009
    Got it!!!!!!!!!!!!!!!!!!!!!!! put back in both radio fuses and info fuse read fine.......
  1. Help Please**** LLY With A LBZ Computer Stock Truck
    By Duramax 6.6L in forum Diesel
    Last Post: June 2nd, 2010, 12:48 PM
  2. Stock truck idle problems after flash..?
    Last Post: August 28th, 2009, 09:07 AM
  3. Tune for 07 6.0L truck?
    By 07.5duramax in forum Gen III V8 Specific
    Last Post: February 25th, 2009, 05:54 PM
  4. Truck Tune
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: May 13th, 2007, 02:25 PM
  5. Help with tuning stock truck
    Last Post: February 23rd, 2007, 10:27 AM
