Hi all, Ive searched, but not yet found the answer.
If I command 14.63 at some point and go into closed loop with STFT's do I also get DFCO and Lean Cruise enabled if these are configured to do so?
2014 VF SV LS3 Maloo.
Think of the custom OS's as the stock OS with some modifications. The entire OS wasn't re-written, so I would fully expect standard features to still function. I can absolutely tell you that DFCO does work, and because you have a Holden/HSV I would fully expect lean cruise to function also.
Andrew
EFILive Crew
Excellent. No point messing with the stock OS then.
Did my first autotune run today. More tomorrow and friday.
Thanks Andrew,
No problem at all. Pleased everything is going well!
Andrew
EFILive Crew
