Results 11 to 20 of 26
Thread: Help! How to put tunes on my v2
  1. #11
    Quote Originally Posted by macca_779 View Post
    Guys I'm having a small issue with BBF. I can BBR and then BBF that same file no problem. But if I load a fresh .ctd file that I made in the tune tool and then proceed to flash it I get a script error. I would have thought if it was a missing script for the LS1B controller I would never be able to BBF. So I got nothing.. Help please.
    Also are there plan to be able to dump files directly on to an SD card through a card reader without the need to use the V2 and EFI Explorer? I did try to see if it worked but the V2 wont see it.
    macca,
    This is with your LS1B PCM...?
    Are you using the tunetool from build 109 to save the .ctd...?
    I pm'd Tech Support.
  2. #12
    Similar problem for me, Im having issues re-saving a *.tun into *.ctd format. I get an error as well, Ill have to check what it is when I get home.
    As for the SD card, I popped mine from my freshly formatted and updated V2 into my laptop and uploaded a few tunes and logs directly from Windows Explorer.
    Quote Originally Posted by LS1FREEK View Post
    Ok, joecar, i did all the stuff you asked for but i'm a little confused about the bootlog and firmware upgrade. Now if i understand correctly, even though my v2 control panel shows that my v2 has the latest firmware and bootlog, it probably doesn't? Because i never updated them through the EE, i just always updated them through the control panel. The simple way..
    If you went through EFILive HAPI Control Panel, then you should be fine!
    macca,
    Same for me, build 109.
  3. #13
    Lifetime Member macca_779's Avatar
    Jan 2007
    macca,
    Yeah everything is the latest version Joe. It is for an LS1B.
  4. #14
    Saving a modified tune as a *.ctd file using the V7.5.6 build 109 will result in the segment checksums not being updated in the *.ctd file.
    The workaround is to save the file as a *.tun file first which will update the checksums, then without making any other modifications to the calibrations, use File->Save As to save it as a *.ctd file.
    A fix (build 110) will be available asap.
  5. #15
    That's why it worked on my LS1B, I saved already existing .tun files as .ctd.
  6. #16
    Jun 2008
    I keep getting "ERROR: $0502 script file not found." Every time I try to flash a .ctd tune on my 06 Silverado LM7 5.3... I did all the stuff it said to do on the March 30 update thread.. Here's what files I got...
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
  7. #17
    Jan 2007
    Thanks Paul. I don't recall modifying the tune prior to saving it as a .ctd file, but its possible I did. I'll give it another go in a few hours.
  8. #18
    Send your Options.txt file to me at paul@efilive.com. You can save the Options.txt file by clicking on the [Save] button in the Black Box Setup window of the V8 Scan And Tune software.
    Include a link to this thread in your email.
  9. #19
    Jan 2007
    Ok I just tried it again and still no joy. Still getting the $0502 error. I even tried to Save As a new .tun file and then make a .ctd off that. And to recap. I have no problem performing a BBR and then BBF it back in.
  10. #20
    Jan 2007
    A further update. I have installed the latest updates just then and tried again. Still no different. This time I even trimmed out all the controllers I don't use and updated my LS1B PIDS to what I use.
    Attached is my options.txt file
    [edit] the new firmware is not letting me BBR now. Comes up with error $0525 *.ctd file not compatible with firmware.
  1. Converting DSP2 tunes to DSP5 Tunes
    By BlkMax in forum Duramax LB7
    Last Post: March 6th, 2009, 10:14 AM
  2. DIF OS Tunes
    By ColbyColorado04 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 18th, 2008, 05:29 AM
  3. Need Tunes
    By evils1z28 in forum Gen III V8 Specific
    Last Post: December 1st, 2007, 11:40 PM
  4. any 5.3 tunes?
    By dynarex in forum Gen III V8 Specific
    Last Post: May 30th, 2007, 02:42 AM
  5. Would unlocked tunes encourage you to pay for more tunes?
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 11th, 2005, 01:09 PM
