What would I set B4349 & B4350 for 102mm Throttlebody...Thanks.................Paul
i did a 2000 vette without changing these, it went okay.
Regards, Odd Boy
Originally Posted by odd boy i did a 2000 vette without changing these, it went okay. Thanks odd boy.I left those tables alone,Believe or not,It idles alot better with the 102mm then the 90mm Can't believe at all the help I got here
Paul, glad you found an answer...
Originally Posted by driver456 Thanks odd boy.I left those tables alone,Believe or not,It idles alot better with the 102mm then the 90mm Can't believe at all the help I got here The vette I talked about, has TT and made 750 tq and 650 hp with 4200 converter & Auto transmission!! It is idle better, run much smoother ...etc
Forum Rules
