Results 1 to 10 of 14
Thread: Changing the VIN Number
    Senior Member Behold's Avatar
    Apr 2010
    Default Changing the VIN Number
    I have a PCM with the incorrect VIN Number to my car. I have read i can change this. Can anyone point me in the right direction??
    No problem, open up the V7.5 Scan tool and click the green button on the upper left hand side. Select the controller your car uses and then press ok. Now go Bidirectional->Change VIN. Enter the VIN you want and press ok. Should be good to go, I believe you have to turn the ignition off for 15 seconds after a VIN write just like a normal flash.
    Apr 2010
    What effect does the vin have on the software version? I.E if im running an 04 ECU from on a 99 Car? will i get an incompatability???
    No not at all, EFILive doesn't use the VIN for any licensing details for starters.
    The scantool will negotiate with the ECU what PID's are supported so again the year shown in the VIN doesn't matter.
    Apr 2010
    Can this also be used to change the vin number in a radio from another automobile? I have a radio from a wrecked 2001 Sunfire and need to put it into another Sunfire, but the radio has the vin from the wrecked Sunfire stored in its eeprom and goes into a lock mode.
    Glenn
    Nov 2006
    No.
    LC-1 WBO2
    Quote Originally Posted by thomasthigpen@att.net View Post
    Glenn
    As mr.prick said, EFILive cannot do this. You have to take it to a dealer and have them use a Tech II to reprogram the radio.
    Apr 2010
    I hear i might produce and invalid pair??? Does that make sense?? Im on a steep learning curve at the moment....
    As to the scantool. You say is works out which pids. don't you have to tell the scantool what pids your car has to start with fo it to check?
    Lifetime Member macca_779's Avatar
    Jan 2007
    Quote Originally Posted by Behold View Post
    You can select whatever PIDS you like. But the software will perform a sanity check once comms is established to validate if you can log those PIDS or not.
    Jan 2016
    All, I am new to this forum as of today. I have a 2009 Sierra 2500HD CCSB LMM. I have acquired a downer PCM from an 08 LMM, Bosche P#12628593, same as my stock 2009 in-use PCM. Can I use EFILIVE V7.5 to read the downer imbedded content (after installing in my truck but not starting), and change the VIN in the downer to match my truck without needing an EFILive license for the downer PCM? Also if I simply power on the truck but don't start the truck will the downer PCM populate any harm to my other modules, TCM, BCM, etc.?
    A simple yes or know answer is adequate, unless there are gotcha's or caveats I need to know!
    TIA for your assistance.
  1. 06 LBZ PCM Part Number
    By SSTuner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 17th, 2007, 11:42 PM
  2. New part number for E67 ecm?
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2007, 01:21 PM
  3. Replies: 2
    Last Post: November 29th, 2006, 12:37 PM
  4. Number 1
    By TAQuickness in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 1st, 2006, 03:13 PM
  5. holden vin number
    By MICK in forum General (Petrol, Gas, Ethanol)
    Last Post: December 28th, 2005, 08:54 AM
