Andy, look at this:
The lambda expression from the LC-1 is: lambda = 0.1361*v + 0.6803
stoich 14.70: AFR = lambda * 14.70 = 2*v + 10
stoich 14.63: AFR = lambda * 14.63 = 1.991*v + 9.953
stoich 14.12: AFR = lambda * 14.12 = 1.921*v + 9.606
stoich 9.78: AFR = lambda * 9.78 = 1.331*v + 6.653
which is what I calculated yesterday.
Yes, do like 5.7ute said, program the LC-1 to with 14.12 and use the E10 pid, let's see what it says.
Yes, set all 3 like this:
If you use E85, then set them (1 and 3) to 9.78 and use the E85 pid.Originally Posted by 5.7ute
joe one other thing... why does my wb match efilive when i set b3601 to 14.63 and program the lc1 to 14.7 and use the 2 + 10 pid? like i said its so damn close, why tho? any ideas?
01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
