Thread: 1990 Olds Toronado
    Apr 2010
    Default 1990 Olds Toronado
    Please,Has anyone got the reference definitions for the 1990 Oldsmobile Toronado? For the VIN C LN3 (SFI) V6 3.8L 3800 4 spd Automatic?
    TORO=muscle
    NADO=speak
    Oct 2004
    Sorry we don't have any information at all on that vehicle we can even provide for you to create the necessary Vehicle Definition I'm afraid.
    Andrew
    EFILive Crew
    Apr 2010
    Default 1990 Toronado
    Tordne Sorry we don't have any information at all on that vehicle we can even provide for you to create the necessary Vehicle Definition I'm afraid.
    Thank You for your reply.
    I have the V4 Eval ; If I were to enter the vin info eprom ID etc, will I be able to read the parameters from the vehicle?
    Oct 2004
    Without a vehicle definition you will not be able to read PID data from the vehicle at all with EFILive V4. Basically what the vehicle definition achieves is the mapping of data coming off the vehicles bus and which 'bits' relate to which PIDs and there respective scaling etc.
    Andrew
    EFILive Crew
    Oct 2004
    It's your lucky day We do apparently have a specification for that vehicle which I am going to email you in a couple of minutes. you will however need to go through this file and convert it into a EFILive V4 vehicle definition file. I'll also send you another specification file for a definition that already exists which will hopefully aid you in creating the definition (for comparison purposes basically).
    Andrew
    EFILive Crew
    Apr 2010
    That would be just awesome Tordne, Thank You.
    I am more of a nuts and bolts, shade tree mechanic, so if you would please include the proceudures to perform the task I am gratefull for your considerations.
    9TTORO
  1. Can't get my 1990 Lumina to talk to EFILive V4
    By MikeRowand in forum EFILive V4
    Last Post: July 29th, 2008, 12:15 PM
  2. 95 olds data stream
    By LikeToDrive in forum EFILive V4
    Last Post: November 30th, 2006, 11:48 AM
