Results 1 to 9 of 9
Thread: EFILive v4 problem
    Apr 2010
    Default EFILive v4 problem
    i got this coming up ???
    57:37.328: Check vehicle interface...
    57:37.342: Interface not checked because 160-baud interface is selected
    57:37.342: Scanning for heartbeat and chatter frames...
    57:37.342: Waiting for Aldl bus silence of at least 50ms...
    57:38.494: Com timeout: Expecting frame header byte
    57:38.512: No chatter found
    what do i do?
    Oct 2004
    Is 160 baud the correct setting for your vehicle? The other option is 8192 baud; this is often a problem if using a USB/Serial converter which does not support that rate.
    The other thing to try is setting timeout values for T6 to 10ms.
    Andrew
    EFILive Crew
    Apr 2010
    Well the vehicle is a Vn 5L so is that the right settings?
    Oct 2004
    In that particular case I would expect the baud rate to be correct. But do try lowering the T6 chatter value to 10ms.
    Andrew
    EFILive Crew
    Apr 2010
    14:30.920: Opening COM1 160,8,N,1
    14:35.857: Check vehicle interface...
    14:35.866: Interface not checked because 160-baud interface is selected
    14:35.873: Scanning for heartbeat and chatter frames...
    14:35.873: Waiting for Aldl bus silence of at least 50ms...
    14:37.023: Com timeout: Expecting frame header byte
    14:37.040: No chatter found
    15:33.816: Updating vehicle information...
    15:33.936: Opening COM1 160,8,N,1
    15:37.324: Check vehicle interface...
    15:37.334: Interface not checked because 160-baud interface is selected
    15:37.334: Scanning for heartbeat and chatter frames...
    15:37.334: Waiting for Aldl bus silence of at least 10ms...
    15:38.443: Com timeout: Expecting frame header byte
    15:38.457: No chatter found
    17:28.498: Updating vehicle information...
    17:28.615: Opening COM1 160,8,N,1
    18:40.379: Check vehicle interface...
    18:40.388: Interface not checked because 160-baud interface is selected
    18:40.388: Scanning for heartbeat and chatter frames...
    18:40.388: Waiting for Aldl bus silence of at least 50ms...
    18:46.793: Can't find silence greater than 50ms
    18:46.797: Hint: try halving T6 from 50ms to 25ms
    18:47.081: Error: Reply frame checksum failure
    18:47.083: No chatter found
    19:17.436: Updating vehicle information...
    19:17.548: Opening COM1 160,8,N,1
    19:19.652: Check vehicle interface...
    19:19.661: Interface not checked because 160-baud interface is selected
    19:19.661: Scanning for heartbeat and chatter frames...
    19:19.661: Waiting for Aldl bus silence of at least 25ms...
    19:26.076: Can't find silence greater than 25ms
    19:26.091: Hint: try halving T6 from 25ms to 12ms
    19:27.164: Error: Reply frame checksum failure
    19:27.170: No chatter found
    19:43.808: Updating vehicle information...
    19:43.931: Opening COM1 160,8,N,1
    19:45.497: Check vehicle interface...
    19:45.506: Interface not checked because 160-baud interface is selected
    19:45.506: Scanning for heartbeat and chatter frames...
    19:45.506: Waiting for Aldl bus silence of at least 12ms...
    19:46.593: Error: Reply frame checksum failure
    19:46.613: No chatter found
    I noticed under the Application tap it said VN/VP but says liters 3.6 not 5.0L and saying v6 not v8? as far as I am aware this is the correct code for my car VN68VP68
    Oct 2004
    I'd say you have the right file. The XML file name should be 'gmh-vn68vp68.xml' which is for the VN V6 & V8 and the VP V6 & V8.
    Couple of things to ask:
    - Is the PCM stock or has it been programmed? I'm aware from previus cases where the chip has been changed they don't work the same as factory and the V4 software does not work with them.
    - Do you have another vehicle (friend perhaps) that you might test with? That would validate a few things (cable, configuration).
    Andrew
    EFILive Crew
    Apr 2010
    - Is the PCM stock or has it been programmed? I'm aware from previus cases where the chip has been changed they don't work the same as factory and the V2 software does not work with them.
    I tried with a V6 VN and same thing happening :(
    Oct 2004
    Is you vehicle chip stock or is it a performance chip (see my previous post)?
    Andrew
    EFILive Crew
    Apr 2010
    Well the v6 commy is for sure. mine I not to sure about
  1. reading Problem ( LC-1 logwork & gage & EFIlive )
    By Ls1_Rulz in forum FlashScan V2
    Last Post: October 17th, 2008, 06:42 AM
  2. Problem with EFIlive and TCM
    By Rvettej in forum Gen IV V8 Specific
    Last Post: October 8th, 2008, 04:27 PM
  3. Problem with EFILive Scan Tool V7.5.4 (Build 6)
    By Kevin Doe in forum General
    Last Post: September 18th, 2008, 04:43 PM
  4. Vista EFILIVE problem
    By 455sd in forum General
    Last Post: March 7th, 2008, 03:58 AM
  5. EFILive Connection Problem
    By jogasz28 in forum General
    Last Post: November 11th, 2006, 09:11 AM
