Try altering the PE settings so PE comes in sooner. Then alter the PE commanded AFR's so that at "cruising" speeds, you run a "leaner " PE. For example, you might set PE AFR's to be 14:1 at 1000 RPM and slowly richen up to 12.4:1 at 2500 RPM. This way you will drop into a richer mixture when you load up the motor more for cruising, but still have plenty of fuel available for WOT runs.
Simon.
