Results 1 to 4 of 4
Thread: 6l90e
    Nov 2009
    Default 6l90e
    I have an 09 CTS-V that has a lot of work done to the enigne and I am try to get the car so I can leave it in drive at the race track and it will handle the shifting. I thought I changed all of the correct fields to accomplish this but the car is still shifting several hundred rpms lower then I would like. There seems to be 4 upshift tables in the transmission tune. WOT, pattern A, pattern B and tap up / tap down. I have changed the WOT and the TUTD but still not getting the desired rpm.
    Gene
    Mar 2005
    I had the same problem with my Camaro shifting at 5600 RPM with the WOT RPM set factory set at 6000. I found the WOT Shift Speeds changed it. It was set at 28 MPH stock and 31 made it shift at 6000, and 32 at 6200. I have the WOT RPM set at 6100 and WOT speed set at 31MPH and it shifts at 6100. Hope this helps.
    Ron
    2014 Silverado 4X4 6.2L
    2010 Camaro 2SS-RS L99
    2007 Sierra Denali 6.2L
    2005 1500HD 4X4 Quadrasteer 6.0L, COS3 SD
    Post the trans file and lets have a look!
    Good point Ron, make sure the part throttle shift tables are setup properly with regard to RPM as well as speed.
    Nov 2009
    Default Files
    OK. I am very new at the EFI live. I used to have an outlaw TT camaro with a Felpro but this is way different.
    High RPM Shifts 4-12-10.tun
    High RPM Rev Limiter 4-7-10.tun
  1. 6l90e in a 6l80e car
    By b18cls1 in forum Gen IV V8 Specific
    Last Post: October 7th, 2009, 11:24 AM
  2. 6l90e
    By 69camaro5speed in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 24th, 2007, 10:43 AM
