When trying to control idle speed or rail pressure it says in a big red strip above the control button NO REPLY TRY AGIAN. Any help? I am running the latest version March 30th build (112).
same has happened with me. I have never been able to use any of the dvt features.
Custom Tuning Services
Huh I have some of them work but not the vane position. when i set the control it just goes to 25 percent no matter what i set it to and stays there until i release control of it. At least on the LBZ. what you guys working with?
I just installed the auto update last night from a week or so ago and had the same results on an 01 lb7 last night. I updated the boot block and firmware and got the big red strip accross the top saying no reply try again. is there a fix for this? or did I do something incorrectly?
An LB7 now, so it would appear all Diesel DVT's are dead?
something killed them?!
I didnt test on my lbz yet i'l try tonight to hook up and see. I had most DVTs working on my truck before I updated. I never was able to get the WIF light to light with the controls but I Was able to do fuel presure and idle speed. I dont recall testing the vane position. but i'll see if anything works tonight and report back.
heh thats the exact thought I had... but I thought houw could it be burned out if its never been on. I have a spare sensor I should plug it in and push the float up to see if it actually works
well seems most things work. idle, rail pressure. the vane position only goes from 4% up to about 39% even if I go from 0 to 99 on the slide.
