trac control off, maf enabled still- what am I missing???
more Power?
Post up your current tune rubbersidedown
FLASHSCAN V2 & AUTOCAL
Maybe your tires are just too good (too stickie..)....
You can also adjust your air pressure if burnouts are your thing. Just be careful not to blow out your tire or break an axle.
I mean come on... I don't think it's a tune problem... why do we try to solve everything with a tune?
If traction control is off a burnout shouldn't be a problem...
We just want to look at his files to see what he should be able to do.
It is actually a problem with the EBCM, but it should be fixable in the tune, or with a zip tie.
http://www.ls1gto.com/forums/showthr...omatic+burnout
http://www.ls1gto.com/forums/showthread.php?t=256390
These should help, you can tune it out, but it was a problem on some 2006 automatic cars.
My 2006 manual has no problem with burnouts.
Ryan
Max out BO704 and check BO701
That took the tires clean off my old Volvo with 12603159 operating system.
Good Luck....Nothing worse than a GTO that won't burn the tires!
