Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Constant Disconnects and Detection of Interface
  1. #11
    This cable is compatible with the AutoTap interface:
    http://www.efilive.com/index.php?pag...mart&Itemid=56
    Its only $19, however the shipping from NZ would be about $40 overnight or around $5 by post.
    Maybe AutoTap (www.autotap.com) still sells replacement cables. I know that when they did, it was around $19 also. If you can get it through them then the shipping would only be a few dollars.
    Or you can make one yourself by purchasing an OBDII cable end here:
    http://www.multiplex-engineering.com/cables.htm (see cable #15) and then soldering your own 9 pin female serial plug onto the end.
    The wiring pinouts are described on page 3 of this document:
    http://download.efilive.com/Tutorial...20Tutorial.pdf
  2. #12
    Jul 2004
    That looks like a V1 OBD cable, I have plenty in stock for the same price as the web site and a lot less shipping because I'm in Los Angeles.
    Ira
  1. Constant 02 sensor codes
    By RevGTO in forum Gen III V8 Specific
    Last Post: June 7th, 2009, 11:07 AM
  2. stock n02 reading constant 0.45mv
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: August 16th, 2007, 12:13 PM
  3. Question about Knock Detection
    By dc_justin in forum General
    Last Post: June 23rd, 2006, 02:30 AM
  4. Modifying misfire detection tables ?
    By kp in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2005, 02:09 PM
  5. Misfire detection table
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: January 20th, 2005, 10:16 AM
