Results 1 to 7 of 7
Thread: 09 LS3 TB difference
    Mar 2005
    Default 09 LS3 TB difference
    I picked one up for an L92 being installed in my 00 C5 and I'm just finding out that the later LS3 TB's are different then the earlier LS3/LS2 version.
    Can tuning eliminate that difference or am I outta luck and just need to sell?
    Apr 2008
    Did you try it? Did you face any problems?
    Regards,
    Odd Boy
    Dec 2007
    Quote Originally Posted by ForcedC5 View Post
    It may be possible to tune it. It responds differently at idle and has been known to pop throttle position faults. Never gone the whole hog on trying to get past this as it is easier to swap. Even LS3's this came on have challenges when blown.
    Mar 2005
    Quote Originally Posted by odd boy View Post
    Yes. I used the adapter to adapt it to an LS1 harness and when I turn the key all I get is Reduced Engine Mode and faults on TP Sensor. Start and it won't hold idle.
    Plugged the original LS1 TB and no faults and it runs.
    Mar 2005
    Quote Originally Posted by gmh308 View Post
    The car's been down for a year so it's been a while since I've touched EFILive. I've got to get in there and remember how things are done.
    Any suggestions on pids set vs actual to monitor?
    It would be great to get these to work since there is a huge cost difference between it and the earlier LS2's.
    Mar 2005
    I just saw a post on another forum stating the HPTuners folks are able to tune it out.
    (and it appears HPT has included the ability to adjust the error % on the throttle now) it is also that they require a different calibration for idle/low speed air flow so they idle nicely.
    Senior Member doubledip's Avatar
    May 2008
    i know its for another forum, but do you have a link to the thread?
    interested to see
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
  1. Difference in LTFT's
    By vsocks1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2009, 09:45 AM
  2. What is the difference between shifting VSS and RPM?
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2008, 06:34 PM
  3. Wideband vs. EFI AFR Difference
    By MoTruck in forum General
    Last Post: December 18th, 2006, 11:50 AM
  4. LTFT difference
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2006, 01:28 PM
