Results 1 to 10 of 11
Thread: Non-Emissions or Not Reported?
    Aug 2008
    Default Non-Emissions or Not Reported?
    Working on a GEN3 2002 5.3ltr motor in a Sandrail(Off Road Only)....Owner wants to run OLSD, no O2's, no MAF. Will it make a difference, or matter if under Engine DTC Processing Enabler's I change all O2 sensor's from "2 trips, Emission Related" to "Non-Emission" or "Not-Reported"?
    I thought I read a post/thread about it somewhere on the forum(can't find it) where it said it did matter...
    FLASHSCAN V2 & AUTOCAL
    Jul 2008
    Gameover:
    Joecar recently highlighted that unless you throw a DTC your MAF is not failed.
    It does, but only if C6001 has P0101,2,3 not set to Not-Reported or Non-Emissions (i.e. those two will prevent a DTC... a DTC is required for failover to VE)... not exactly 100% sure about Non-Emissions.
    I.E. Do not set it to Not-Reported or Non-Emissions..
    I always allow my MIL to illuminate during MAF failure and double-check that it throws a DTC..I never realized that some people change it. If anything I go One Trip, Emissions Related, to throw the DTC immediately.
    I am pretty sure I got this right. Please comment if wrong..
    Thanks..
    Default Off Road Usage Only
    Set the O2 DTC's to Not-Reported, leave the MAF DTC's as A:1-Trip.
    (SD requires a MAF DTC to be present)
    If you leave the other DTC's alone, then you will have some indication when something breaks (e.g. TPS wiring, MAP sensor)... i.e. the PCM can detect wiring problems (opens and shorts and incorrect sensor voltages).
    For offroad use in Mexico only.
    Edit: I looked at some HSV files and I see that Non-Emissions would work also... I'll try this myself shortly.
    Jul 2008
    Here are a few other 'sanity' checks users can use to see if they have successfully failed the MAF (other than DTC).
    This is from my own personal observation of OS 12212156..
    1. Log Both GM.CYLAIR.DMA and GM.DYNCYLAIR.DMA PIDS.
    If MAF failed they will log identical values.
    2. Only the LOW-OCTANE SPARK Table will be active. You can alter it +/- 1 degree from High-Octane to verify running off Low-Octane Spark.
    3. Log GM.ASPARK. If MAF Failed it should read 0%.
    Again, all personal observations. I like to log MAF Freq and g/s when I test MAF failed. The biggest hassle for me is to remember if and when you go back to MAF-Enabled, ASPARK remains at 0, until you all the parameters of B6213-B6217. That one drove me crazy for a while.
    Hope that helps. Again, if I have misstated please correct. Nothing worse than tuning MAF Failed and its not...
    Nice one about off-road use..
    Aug 2008
    Thanks fellas...
    That cleared it up for me.
    Game, check the SD mode using the methods Shawn and Joe have suggested. If the owner wants to leave it in OLSD, use a COS so retain the high and low spark tables.
    Aug 2008
    I have used SD successfully quite a few times(COS 3 & 5), but lately(OFF ROAD ONLY)GM people want to go OLSD, they want to run less & less factory sensor's and for some reason don't want to use front or rear O2 sensor's. I was really trying to understand under the DTC Processing Enablers, what to set the O2 sensor's to, when they are not being used...
    Ive been trying to figure that out as well for a while, the DTC enablers/checks/etc arent my strong suit yet.
    Aug 2008
    Yeah Eric, mine either...
    Oct 2007
    u can even set it to non emissions, i passed my obd2 test w/ it set to non emissions
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
  1. Difference between Non Emissions and Not Reported?
    By turbo_bu in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2010, 04:45 AM
  2. New emissions laws
    By GMPX in forum Lounge
    Last Post: June 5th, 2009, 05:33 AM
  3. Can't pass emissions?
    By WS600 in forum Gen III V8 Specific
    Last Post: March 11th, 2008, 12:37 AM
  4. Right voltage wrong AFR reported??
    By Redline Motorsports in forum General
    Last Post: July 23rd, 2006, 03:19 PM
  5. emissions
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2006, 09:07 AM
