Results 11 to 20 of 27
Thread: 06 gmc truck os swap?
  1. #11
    Just looked at a few files on HoldenCrazy.com, didnt see a ETC OS with an 80E, I thought I might get lucky with the 8.1L OS, but they use the Allison 1000 trans.
    Might have to do the 80E using a 60E OS for now.
  2. #12
    Nov 2009
    Please don't tell me that! If I have to do some more wiring mods it will have to be free because I think I already earned all the money he had. Plus Aric needs that truck done and gone and I am in the middle of a '98 Vortec 5.7 injection swap in an '86 K1500 at home. So I really don't need to pull off of it until I'm done.
  3. #13
    The C/K truck platforms had the 4L80E as an option (it shows up in my 2005 Service Manual DVD)...
    someone somewhere must have 1MB LS1B 4L80E file.
  4. #14
    Nov 2009
    Thank you both for the help so far. I'm going home for the night, but Aric may be back on. I'll bring my laptop to work tomorrow in case we can come up with a solution so I can go to Injected Engineering after work.
    Thanks again!
    Brint
  5. #15
    Mar 2009
    Hows this Joe?
    LS1B 1 MB 6.0/4L80E and ETC.
    Note: this is not a bone stock tune, just the only one I have available on this computer right now that may be helpful.
  6. #16
    That's a 1MB 4L80E 12613248 file with Flex-Fuel and ETC. Edit: I looked closer at that file and I saw FF set to No.
    The 1MB 4L60E 12606807 file on www.holdencraqzy.com also has FF and ETC.
    One would think those OS's are compatible, but I don't want to make an assumption, let me ask someone...
  7. #17
    Nov 2009
    Do you mean that Aric may be able to use an OS for a flex fueled engine and just calibrate the engine segment (which he still has to do anyways, turbo setup)?
  8. #18
    Nov 2009
    I have a friend about 2 miles down the road who has a stock 07 2500hd 6.0 ETC 4L80E, and he says its not a Flex-Fuel. Can I just go down there and pull his .tun file and give it to Aric, or does doing an entire OS upgrade involve more than that? In case we don't get super lucky and have the same OS as the truck Aric is working on.
    Brint
  9. #19
    I think the attached files will do the job for you.
    1Mb PCM
    4L80E
    Non Flex Fuel
    ETC
    6.0L
    The 2006 Hummer 12613246 OS is the closest to the one you already have, in fact it was an update to the one you have, so I'd suggest full flashing that in.
  10. #20
    Nov 2009
    Thank you very much GMPX, and all! Aric will soon be a proud new owner of EFILive. Will post results tomorrow, not that you or I have any doubts.
  1. 4L80E swap into 2006 6.0L truck with 4L60E
    By powermonger in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2010, 03:59 AM
  2. sterio swap and truck wont start
    By pullincrazy88 in forum General (Diesel)
    Last Post: September 2nd, 2009, 02:42 AM
  3. E38 gmc 5.3L truck ???
    By 1FastZ in forum E37, E38 & E67 PFI ECM's
    Last Post: September 20th, 2007, 07:39 AM
  4. IFR for truck
    By Grey Silver in forum Gen III V8 Specific
    Last Post: July 26th, 2007, 03:40 AM
  5. Put Z06 cam in 4.8 truck
    Last Post: August 16th, 2006, 09:27 AM
