Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 06 gmc truck os swap?
  1. #21
    Nov 2009
    I left my software paperwork at home and I need to buy a PCM liscence today. Is there anywhere I can look in the tune tool to get my serial and authorization #s?
    Hope I didn't screw up!
  2. #22
    Brint, go Help->FlashScan V1/2 PCM/VIN Licensing... you should see serial number and authorization number(s).
    Let us know how it goes.
  3. #23
    Mar 2009
    The tune I posted wasn't setup for flex fuel. It's from an '07 Silverado 2500HD classic also. You can see in B3101 it's factory set to "no". That part I didn't change.
  4. #24
    Quote Originally Posted by Big Mike View Post
    Yes, this morning I looked closer at it and saw that... ...I added an edit comment to post #16 above.
  5. #25
    Nov 2009
    I'm at Injected and downloaded the .tun file for the Hummer and it is a 4L60E. I guess I'll try the van file.
  6. #26
    Ross, the files you posted have very similar OSs, but not exact (Van is 48, H2 is 46) so you cant do a seg swap from the Van to the H2. But the Van file looks to be the best fit!
    vortectoya, Id full flash the Van file in and see if you cant make it run.
    For Paul/Ross, what COS would you use with that 07 Express Van OS? Doesnt look like there are any COSs for LS1 PCMs past the 05 MY. Also, just FYI all the COSs that end in 5 (and appear to be the TPS-VE COS) are still labeled development versions in their description.
  7. #27
    vortecyota/Brint,
    Did you get the PCM license sent to you ok...?
  1. 4L80E swap into 2006 6.0L truck with 4L60E
    By powermonger in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2010, 03:59 AM
  2. sterio swap and truck wont start
    By pullincrazy88 in forum General (Diesel)
    Last Post: September 2nd, 2009, 02:42 AM
  3. E38 gmc 5.3L truck ???
    By 1FastZ in forum E37, E38 & E67 PFI ECM's
    Last Post: September 20th, 2007, 07:39 AM
  4. IFR for truck
    By Grey Silver in forum Gen III V8 Specific
    Last Post: July 26th, 2007, 03:40 AM
  5. Put Z06 cam in 4.8 truck
    Last Post: August 16th, 2006, 09:27 AM
