Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Why negative fuel trims after autoVE
    May 2007
    Cheers Joe, its coming back and that matched what I thought (of course ) about the 1.25 being extra being applied. Of course we have the wideband in now so will log purely on that (gave up on the idea of trimming with the ltft bens and waited). Should be a fun night assuming the replacement LC1 works
    Sanity check the LC-1 by checking Lambda it returns while PCM is commanding CL.
    Jun 2005
    My thoughts on LTFTs from 2 years ago - see post #6.
    http://www.ls1tech.com/forums/pcm-di...uel-trims.html
    Sounds like the OP has stumbled upon some similar questions. If I ever tune a car again to use the fuel trims, I think I might actually target a +5% across the board...not the -1% to -4% that I remember seeing everywhere I looked back in the day.
    Nov 2006
    LTFTs are impacted by the dynamics tables as well.
    After installing some new fuel injectors (ASA 38lb) with their "known" offsets,
    LTFTs under decel were highly negative.
    I reduced the impact & evap factors by X.XX% and got them inline.
    This may have been needed because of the extra CI my engine has now.
    Otherwise the "known" injector settings may have worked.
    High positive & high negative LTFTs can cause severely incorrect fueling.
    LC-1 WBO2
    Feb 2007
    I have found that slightly positive trims gave me some knock pretty evenly across the map, I'm at the limit of the knock threshold for g cyl. What this has showm me that the GM Hi octane map is the correct shape for my set up, for the solution I have moved the Hi octane map all one cell to the left. I will add back incremenatally until I see knock in any cells.
  1. E38 fuel trims
    By minytrker in forum Gen IV V8 Specific
    Last Post: July 2nd, 2010, 02:44 PM
  2. Fuel Trims for 12.5 AFR with LC1
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: February 19th, 2010, 04:25 PM
  3. HELP fuel trims and AFR all over the place?
    By warscout2 in forum Gen III V8 Specific
    Last Post: January 30th, 2008, 11:31 PM
  4. L-trims positive after AutoVe tune?
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2007, 05:22 PM
  5. Fuel Trims are 0
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2007, 04:15 PM
