Results 1 to 10 of 15
Thread: Why negative fuel trims after autoVE
    Feb 2007
    Default Why negative fuel trims after autoVE
    Ive been thinking about the general advice for LTFT after AutoVE of the VE table, LTFT's should be -1 to -4%, because if positive extra fuel will be added in PE mode.
    LTFT's only add fuel in PE, they do not subtract.
    Which makes me think if the LTFT's are negative and the adjustment isn't made in PE mode then AFR will be rich than the commanded PE AFR anyway, by not compensating for the LTFT -% value. Which kind of defeats the reasoning behind not having positive LTFT's.
    How ever, if you have positive fuel trims, fueling is corrected in CL and fuel also added and thus compensating when in PE mode which should be to the commanded PE AFR?
    I also not that if the VE table is not as close to BEN = 1.0, then the predetermined (stock) spark value will not be at optimum. If you add to the VE table so that LTFT's are negative, the calculated g/cyl value is higher than the true value and thus a lower spark value is looked up.
    Like wise if the VE table is lower and LTFT's are positve, the g/cyl value is lower than the true value and the spark value looked up will be higher. However, I think with dynamic fueling the PCM will go with the MAF g/cyl value and not the VE table in this circumstance.
    Any thoughts?
    Jul 2008
    Quote Originally Posted by Gelf VXR View Post
    Any thoughts?
    I personally think you are correct in all your points. I try to get my LTFTS near zero. The problem is it makes WOT fuel computation difficult with + fuel being added. But, you are right. You have to then manipulate the airmass calculation in PE Mode to get the right WOT Commanded Fuel. Then to further complicate matters, if you hit PE in a lower RPM, chances are (if MAF-enabled) the MAF Freq (g/s) value was adjusted for a negative trim..now your too rich for WOT.
    You are also correct that when any manipulation of the airmass (VE or MAF) alters the load computation for spark. In just the manner you described.
    It would be a nice option to be able to just adjust the Trim for specific FTC cells. You might be able to eliminate that problem. Or if MAF tuned, a PE Threshold that operates by MAF Freq instead of MAP.
    I would just try to get your LTFTS as close to zero..Then fueling and spark computation will be very close.
    Good observations..
    Nov 2006
    Always filter out positive LTFTs during PE.
    I agree with Shawn if LTFTs are screwed up after OL tunig what was the point?
    LC-1 WBO2
    Feb 2007
    Quote Originally Posted by mr.prick View Post
    I'm not saying your wrong, just challenging the accepted rule.
    We know one bank runs leaner than the other, with negative trims on both banks, the difference is still preverlant under WOT & PE.
    I'm thinkin that if you autove and aim to get your rich bank values 0% to -1% and the lean bank +2% to +3% or were ever they need to be, when you go into PE or WOT, THE PCM will add the xtra fueling to the lean bank only and balance the AFR in each bank.
    Jul 2008
    That would be an interesting log.
    While I think I know where you are going on this..if your wideband is on the + LTFT bank..you can not get your Commanded AFR to match actual. Edit.. I do agree with you that entering PE with a negative value may not match either..
    How do you get around that?
    Last edited by WeathermanShawn; April 21st, 2010 at 08:21 AM. Reason: Clarification..
    Feb 2007
    Quote Originally Posted by WeathermanShawn View Post
    The problem is the MAF value is going to be an average of the values of the two banks.
    If the VE map is dialed in to the rich bank as close to zero or slighty negative and the lean bank is positive, the MAF needs to read the average of the two banks which will be slightly higher than the dialed in VE value for the commanded AFR to match actual. Im not sure how to over come that?
    Edit: a slight adjustment to the MAF calibration could overcome this offset?
    Last edited by Gelf VXR; April 21st, 2010 at 08:54 AM. Reason: added a possible solution
    Nov 2006
    Use an average of both banks for VE&MAF.
    LC-1 WBO2
    Jul 2008
    Gelf:
    I have run into a few more issues with a MAF closed-loop tune than a CLSD tune (in terms of what your are describing).
    There are many, many points of MAF resolution vs MAP/RPM for airmass calculation (disregard interpolation). So in my case 7500-8000 MAF (Hz) may be used both in PE mode and non-PE mode. If you apply LTFTS at 7500-8000 Hz that change the calculated airmass..under a different RPM in PE Mode you may have an airmass calculation that is incorrect for PE Mode.
    Again, whether CLSD or MAF/SD Closed-Loop..I try to aim for zero Trims prior to entering PE. Like Mr. Prick, I use an average of both banks..
    May 2007
    +figures for ltft mean the car is adding fuel yes so tune is lean? So long since I did any of this that confusion is creeping in. If the LTFTben is 1.25 is that rich or lean? I know EQ 1.13 = 12.9 or there about so would indicate rich but is that before or after fueling is sorted. IE if you log 1.25 LTFTBen is that what the car is adding to the mix?
    LTFTBEN 1.25 means that the LTFT's are adding 25% fuel to trim to stoichiometric.
    (LTFTBEN is the BEN derived from the average of LTFT1 and LTFT2)
    so the computed airmass (from either VE and/or MAF) is lower than actual, causing fuelmass (required to meed desired/commanded AFR) to be computed low... this causes NO2 to indicate lean, PCM determines how lean (by looking at how much time the NBO2 signal spends low) and determines LTFT correction which it then applies to the next iteration.
  1. E38 fuel trims
    By minytrker in forum Gen IV V8 Specific
    Last Post: July 2nd, 2010, 02:44 PM
  2. Fuel Trims for 12.5 AFR with LC1
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: February 19th, 2010, 04:25 PM
  3. HELP fuel trims and AFR all over the place?
    By warscout2 in forum Gen III V8 Specific
    Last Post: January 30th, 2008, 11:31 PM
  4. L-trims positive after AutoVe tune?
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2007, 05:22 PM
  5. Fuel Trims are 0
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2007, 04:15 PM
