Results 1 to 4 of 4
Thread: 4L60E shift points
    Apr 2010
    Default 4L60E shift points
    hi all, im new here after just getting EFIlive,
    ive done the simple stuff, EGR del, AIR del, rear O2 del and changed shift times to 0.3 , pressure up by 18% and torque management down by 15%, following joecars trans guide that is floating around on here
    I have a question though about shift points, has anyone changed them such that at lower throttle its changed to a lower speed to cycle through gears faster, but at say 60% + throttle move to a higher speed to hold gears more and be more performance? I also assume I much change all shifts up and down, and the TCC lock up as per the other post lower in this forum section to prevent gear hunting
    Hi maudy, welcome to the forum...
    shift points are a matter of personal preference...
    make small changes to the PT up/down tables and go for a test drive;
    be sure to keep the upshift table above the corresponding downshift table, say by at least 5 mph... this is called hysteresis and prevents gear hunting;
    you'll find that the stock shift points and TCC tables are pretty good for low speed (upshifts quickly, holds higher gear, gives good fuel economy)...
    you can probably make the upper 1/3 of each table more aggressive (hold each gear longer with less throttle, shift at higher speeds).
    [ the tunetool shows the rpm in each gear at the bottom of the display for the cell under the cursor ]
    Try small changes and see.
    Senior Member whackem04's Avatar
    Apr 2009
    "[ the tunetool shows the rpm in each gear at the bottom of the display for the cell under the cursor ]"
    And what a great feature it is!
    How come it doesnt work on the Allison tunes?
    01 GMC Sierra 1500 SLE 5.3 cam swap
    Tuned by ME (COS 5 - running strong and smooth)
    Noted, thanks.
  1. Little help with changing shift points
    By Tarkstoys in forum Allison 5 & 6 Speed
    Last Post: June 29th, 2009, 06:54 AM
  2. tuning shift points
    By hot-dog in forum Allison 5 & 6 Speed
    Last Post: February 28th, 2009, 08:03 PM
  3. shift points
    By rock04max in forum General
    Last Post: December 1st, 2008, 01:09 PM
  4. Help with 80E shift points
    Last Post: May 20th, 2008, 03:08 PM
  5. TCM shift points
    By lakingslayer in forum General (Diesel)
    Last Post: March 28th, 2007, 11:09 AM
