Results 1 to 8 of 8
Thread: B3601 and returning to CL
    Lifetime Member Gregs's Avatar
    Sep 2008
    Default B3601 and returning to CL
    I think i'm getting towards the end of doing autove and I think i'll be returning to CL operation soon and i was wondering if i need to change my o2 switch points because i tuned to an afr 14.12 for E10 gas. What do you guys think? is the computer going to try to adjust back to 14.7 because thats the only value the nb sensors can read accurately?
    on a slightly different note does anyone know which wire i need to tap into on the 02 harness if i want to send a simulated nb signal to the pcm from my wideband?
    thanks!
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Sep 2008
    anyone?
    Stock for now
    Nov 2006
    It will "adjust back" to EQ 1.00
    The PCM and NBO2s don't know AFR.
    What PCM for the simulated NBO2?
    LC-1 WBO2
    Sep 2008
    alright, thanks thats what i was wondering.
    i believe my truck has the p59 PCM. Does that matter for wiring the wideband into the stock wiring harness.
    Stock for now
    Nov 2006
    I'm not familiar with the P59.
    It matters because not all PCMs are pinned the same.
    LC-1 WBO2
    Sep 2008
    oh, ok i was thinking that i was supposed to splice into the connector for the nbo2 that i removed...maybe i'll go another route because i don't really want to mess with the pcm
    Stock for now
    Nov 2006
    You can send the signal back to the PCM thru the harness for the NBO2 but
    you will need to know which wires are the 12v+, ground and the high & low signal.
    I used an old connector from one of my old NBO2's to get 12+ & ground for my LC-1.
    Here you can see someone has incorporated the stock NBO2 connectors to and LC-1 so it can be plugged straight into the harness.
    Connecting the wrong wires together will cause problems.
    Is the PCM an LS1 1mb?
    LC-1 WBO2
    Sep 2008
    oh cool, i have a buddy that might be able to get me a wiring diagram for the nbo2.
    my pcm is a 1mb LS1 i believe. at least thats what efilive calls it when i'm connecting to it to scan or whatnot
    Stock for now
  1. B3601 value for E10
    Last Post: August 28th, 2015, 12:09 AM
  2. Returning to cl maf-problems
    By Gregs in forum Gen III V8 Specific
    Last Post: May 5th, 2010, 06:24 AM
  3. returning to closed lupe after auto ve
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2008, 07:17 AM
  4. O/T: Top Gear is returning!
    By Garry in forum Lounge
    Last Post: December 19th, 2006, 06:38 PM
  5. B3601
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: November 23rd, 2005, 11:24 AM
